No, I assume that I have a full filter and oil channels that has an open end drop to the oil pan. I also think that the back pressure of the oil distribution depends on enough oil going thru the filter or bypass to build pressure against the open-ended distribution paths.quote:
Perhaps ..but you're going on the assumption of an empty oil filter pushing into a void. This is rarely the case. You have no idea of what back pressure the downstream oil system puts on the media.
I agree that this is needed to not poke holes in the filter medium. But when the oil leaves the filter the velocity is right back up there. What's your guess? A couple of inches a second? More? Less? Varies with rpm?quote:
It's also experiencing a radical drop in velocity in the filter can. If you strectch out the filter media into a panel (like many of out air filters have) you would have a, less than, 1/2 diameter flow spreading out over 90-150 square inches of media. Sorta like being on a one lane highway and then having the road broaden out into 50 lanes wide ..and then choking back into 1 lane again. Traffic, so to speak, is at a crawl through the filter.
How is the oil being forced past the "sprung" restrictor when the oil is warm? Is there a thermostat there or what? Now I'm confused? If oil flows easier warm it would tend to go thru the by-pass filter easier and not build the pressure to overcome what you call the restrictor.quote:
Not really The sprung restriction is to force flow to the bypass when the oil is warm. The oil pump IS going to pump what it is going to pump. When warm ...it flows like water. If they didn't have that sprung restrictor ..it would take many miles to accumulate enough resistance in the ff for it to route enough oil through the bypass filter.
I believe they use something like MIL-H-5606 hydraulic fluid. So when they conduct filter tests, it's with a fluid of about 23 cSt at room temperature, which is equivalent to the typical 5w30 oil at 65-70C (149-158F).quote:
Originally posted by edwardh1:
Purolater says:
PureOne filters meet the flow requirements of automotive applications. We
test our filters per SAE specification HS806 Chapter 1, and the standard
flow rate requirement that we follow states that the pressure differential
(between inlet and outlet) shall not exceed 3.0 psi at a flow rate of 3.0
gpm. On the PL30001 filters, flow restriction is 0.8 psi (avg) at 3.0 gpm.
I bet this test is done at an elevated temperature - anyone know??
Why aren't we using an SAE test rather than a lets make up out own?????
Okay ..input runner of remote mount ... first in line for a down leg is BYPASS FILTER ...same runner "further in" is SPRUNG RESTRICTER -beyond sprung restrictor - downleg to FF.quote:
It's not identical ..but it works for demonstration purposes. You would have to look at viscosity as a reactive component ..impedence. A 1/32 hole is a greater restriction @ 32°F then it is @ 212°F. Likewise the flow through different media densities will not be in the same proportion at different viscosities. They have a relationship at a given viscosity. If you applied band pass and band reject resonate principles to the two filters run in parallel, the bypass would appear to be an "open", while the ff would appear to be a shunt if the viscosity was extreme. As the viscosity was reduced, the impedence of the dense bypass filter would be reduced and it would "pass" more through it at the same applied pressure. The sprung restrictor raises the impedence of flow to the ff. So when the oil is thick the ff is the only place it can go (almost completelY) ..when the oil is thin the ff has artificial resistance of the sprung valve to make the bypass "pass" more fluid (still much less).quote:
I don't believe in the correlation of electron flow in resistors to fluid flow thru filters.
You don't. You get about 15-20%. The biasing valve just simulates a restriction on the ff to induce more flow (the maximum) through the bypass at all times. Whatever the bypass cannot handle, due to flow/viscosity, will go through the ff. This flow will be the majority in all cases (the ff).quote:
Why would they design the flow to split to 16% to the ff filter and 84% to the by-pass filter anyways?
Purolater says:
Gary,quote:
Btw- just in case you're confused about this point .....the bypass referred to in this post is only called a bypass due to the filter design. It is not run as a "bypass filter" in the common sense of the nomenclature. A bypass filter typically taps off of a pressure point (sender port, etc.) and then just returns to the sump (valve cover, etc.) after going through the dense media.
Filter guy,quote:
The unit saw 100% of the oil pressure but the orifice only allowed a small amount of oil to be filtered. The return line was plumbed back to the oilpan to "by-pass" the oil that is used to lubricate the engine. You wanted no more than 10% of the oil capacity to be bled off and filtered in the by-pass unit.
Try this, if you have filter with a flow rate of 3 gpm at .8 psi restiction and a filter with a flow of 1.5 gpm with a restriction of 1.6 psi you can get 3 gallons thru one and 1.5 gallons thru the other. But if you put both outputs thru a 2 gpm restriction you have almost all the oil flowing thru the 3 gpm filter with .8 restriction, and builds against the 2 gpm and backs up against the 1.5 gpm which will have almost no flow.quote:
Purolater says:
LOL, probably because this is someone's garage not a lab? They are trying to be helpful, but unless everyone here donated $100 at one time it seems unlikly they'll ever get the funds together to build the equipment to do some "SAE test specs and conditions".quote:
Posted above
I agree.
what are the SAE test specs and conditions? thats what the test(s) should be
Let's make sure that we're on the same page here. I can understand the confusion. A bypass filter has no bypass valve. A bypass filter may or may not be used in the manner that assigned it its name. It may or may not "bypass" the engine in doing its task. The common nomenclature has assigned it the "name" bypass filter and encompasses any high density fine filtration media device. A ff filter has a "bypass valve" incorporated that will bypass the filter media to limit the PSID across the ff media. If plumbed in parallel to a bypass (style) filter ..the bypass valve of the ff filter ..will also limit the PSID across the BYPASS FILTER to that same PSID.quote:
Since it is a bypass filter it will go into by-pass mode if the oil pressure is greater than 8-12psi on the high side. That would mean that the spring restrictor would have to open with less pressure than the by-pass of the bypass filter.
Orifices don't work that way. They aren't proportional ...but if you had two filters rated at a given flow ..at a given visc ..and the same PSID ...then the flow would divide proportionally to their given flows. That is, two filters in parallel ..one rated at 2 gpm @ 4 PSID and one rated at 4 gpm @ 4 PSID...at 6 gpm of flow (assuming they were both rated at the same visc for the spec) and @ 4PSID ..the flow would probably be divided 2 gpm to one ..and 4 to the other.quote:
And I thought that a filter with a bypass valve in it was a bypass filter and that a fullflow filter had no bypass and all the oil had to go thru the filter so the full flow has to go thru the filter.quote:
Let's make sure that we're on the same page here. I can understand the confusion. A bypass filter has no bypass valve. ... A ff filter has a "bypass valve" incorporated that will bypass the filter media to limit the PSID across the ff media.
Originally posted by Gary Allan:
You've got to view oil flow along the line of the flow being the dictating constant (at whatever variable rate that may be at the time) and all other things being subordinant to it. Unless the oil pump reaches its relief limit ..100% of the flow is ...100% of the flow (it is what it is) . So 6gpm is going to flow no matter what and the pressures and velocities will change to satisfy the equation that you're working on in your head at the moment. Once you've determined the pressure relief limit of the oil pump ..the rest has to work it self out in the other variables one way or another.That is where you assume wrong. The pump is going to pump all it is allowed to pump because the motor only allows so much oil to pass thru the oil channels. Higher pressure will push more oil thru the same channels. It is the channels that determine the amount of oil flow. That is your 100%. You can't get more oil going thru the pump and filter than what goes into the engine. The pump pushing the oil against the oil gallery, oil passages, or oil channels (what ever you want to call them) is what gives you your oil pressure.
What is PSID? PSI is per square inch but what is the D?
