- Joined
- Sep 28, 2002
- Messages
- 39,799
Well, let's think about this a little more...quote:
That is where you assume wrong.
Well, sorta. The pump is going to pump in relation to its speed. That FLOW will result in a pressure. If that pressure never exceeds the oil pump's internal relief settings ...100% of every drop (except for internal minor leakage) will go through the engine.quote:
The pump is going to pump all it is allowed to pump because the motor only allows so much oil to pass thru the oil channels.
Well, it is more correct to say that higher flow will result in higher pressures. The pressure is a result of the flow ..not the flow dependant upon the pressure.quote:
Higher pressure will push more oil thru the same channels.
No. Your oil pump's volume determines your flow. The restrictions of the channels may determine your pressure.quote:
It is the channels that determine the amount of oil flow.
Please show me where I said this??quote:
You can't get more oil going thru the pump and filter than what goes into the engine.
Absolutely!!! The FLOW that the OIL PUMP is moving produces the pressure.quote:
The pump pushing the oil against the oil gallery, oil passages, or oil channels (what ever you want to call them) is what gives you your oil pressure.
PSI "D" = differential.quote:
What is PSID? PSI is per square inch but what is the D?
When you have a positive displacement pump ..for every rpm you are going to move a given volume of, in this case, oil. The pump doesn't have any other option unless its internal relief settings are reached. Xxrpm ..xx gpm ..no two ways about it. When your oil is cold ..or your filter picks up debris ..the PSI differential across the media will increase. If the differential is in excess of the filter's bypass valve setting ..let's say 12 PSID ..that vavle will open and a portion of the oil will not go through the media. 100% of the flow still goes to the engine ..it is just divided between going through the media and bypassing the media.
Flow is king in this situation ..everything else changes to make the equations work. This isn't like a water line ..a fire hose ..or an electrical outlet. Ohm's law (adapted) applies to a certain degree ..but you've got current (flow) being the dictating element.
