Who will go on the record that 5w30 conventional in winter and conventional 10w40 will kill a normal BMW engine driven moderately with OCIs not exceeding 5000 miles?
It goes back to that argument of "is synthetic 2x as good as dino"?
If I drove 12k a year in a newer BMW and had the choice of 2 changes of dino or one change of BMW synthetic....I grab the 2 jugs of Pennzoil and NEVER LOOK BACK.
As far as HT/HS, OP Temp and wear, Pennzoil Platinum 5w30 seems to work fine in Audis, even turbos, that spec similar oil to the BMW....even in summer. That cannot be disputed.
As far the BMW fanbois with their Mobil 1 5w30, they are retarded, because they don't know enough to make an informed decision. Likely they could get good-as or better results with conventional 10w30. The irony is that they don't probally have any problems because of the issues I mentioned earlier. They probally don't drive as hard as they think they do in terms of really heating the oil to the point the thin visc is a problem. The thin visc probally helps them because they don't observe proper warm-up and hammer the engine cold.
Call them out on it and have them pull a used oil analysis and note their typical max oil temp. Wear will track with temps....like I said.
Paging Dr.Hass to the Oil Phone.
http://www.widman.biz/Seleccion/Viscosidad/Conversiones/Graph/graph.html
