Originally Posted By: mightymousetech
Originally Posted By: Leo99
Originally Posted By: umungus1122
You need to check the level more often. How long did it take to consume 2 qts.?
According to a Scotty Kilmer video on YouTube, there's no dipstick.
BMW does not use dipsticks anymore, have not had them in a long time. But, you are able to check the oil level from the MID while you are driving. Simple to check every time you drive if you want.
To OP, the oil level gauge may not be accurate when the vehicle is cold, or if there is a lot of moisture in the oil. Get the oil up to full operating temp on the highway and check the level again.
FYI - you can no longer check the oil level in BMWs while driving (at least in this model). You've got to be stationary with the engine up to operating temp and in Park or Neutral on a level surface before it will run the diagnostic (and it takes about 120 seconds to measure which means that you can't really just rip off a check at a stop light). There is no way to physically check the oil any more. Everything has to be checked electronically.
The BMW system doesn't even show fill level any more except for immediately after you run the oil check diagnostic. Most of the time, it only shows you a color coded picture of the engine (green for acceptable, yellow for warning, red for below minimum) so it's impossible to see where the levels are trending or how close you are to a warning unless you're in the habit of running the diagnostic pretty frequently.
