Mike - I haven't run across an E85 station in the Milwaukee/Racine area.
What is the brand of the E85 fuel? We have the rather large ethanol plant in Monroe, just west of Madison.
Some good info on E85 Ethanol at this Site.
Per the FAQ's:
What are the differences in an FFV model for E85?
There is only one major additional part that is included on an FFV - the fuel sensor that detects the ethanol/gasoline ratio. A number of other parts on the FFV's fuel delivery system are modified so that they are ethanol compatible. The fuel tank, fuel lines, fuel injectors, computer system, anti-siphon device and dashboard gauges have been modified slightly. Alcohols are corrosive. Therefore, any part that comes in contact with the fuel has been upgraded to be tolerant to alcohol. Normally, these parts include a stainless steel fuel tank and Teflon-lined fuel hoses.
What happens if I accidentally fuel my gasoline-only powered vehicle with E85?
Although your vehicle was not manufactured to run on E85, no problems should occur if you mistakenly fuel once with the alternative fuel. The largest difference between an E85 powered vehicle and a gasoline powered vehicle is that their computer modules are meant to read different amounts of oxygen within the fuel. E85 contains a higher amount of oxygen than gasoline and E85 compatible vehicles are made to read that higher amount. When a higher amount of oxygen is read by a gasoline powered vehicle, your "check engine light" may appear. However, the vehicle will run just as it will with gasoline.
Per the FAQ's:
