Blackstone report on my 02 Accord's ATF
AL
Kind of a noob here - hope I'm putting this in the correct section. My trans shifts like new (4cyl at 73K miles), but knowing that these have issues I wanted to see if an analysis would tell me anything. I do a drain/refill with Honda ATF every 12K-15K (first one at 30K). Anybody see any issues in the report?
There is actually an ATF UOA section.
What was the magnetic drain plug like? More/less wear than normal?
Low mileage. Lots of city driving or does it sit for extended periods?
No leaks I assume?
Originally Posted By: benjamming
What was the magnetic drain plug like? More/less wear than normal? Low mileage. Lots of city driving or does it sit for extended periods? No leaks I assume?
The drain plug had the fine film of goop that I've seen at every D&R. No slivers that I could see. No leaks. The miles are low but the car has never sat for more than a few days since new and the miles are mostly hwy. My commute is only 11 miles (each way), but most of that is going ~65mph. On weekends and long trips the car usually sits b/c we take our van.
