I wanted to check and see if anyone has used BG Dex VI trans fluid? The reason I ask is, the 6L80 crapped out at 88k and had it rebuilt. The shop put in a Billet TQ, Sonnax shift kit and valves and updated the thermostat. After, the vehicle is run for awhile, it has harsh downshifts at 20 & 35 MPH. Because it seems to only happen after being hot, I was wondering if the fluid if the culprit. The shop who did the work doesn't believe so...
I am familar with BG products but not the trans fluid.
Thanks,
Tim
Thanks,
Tim
