I offer this anectdote reluctantly, because I'm not entirely sure of the cause and effect from my experience with various ATF's for my 2000 Tundra (specs DEX II/III). But I offer it because I still think it might have some merit for those folks with similar vintage vehicles.
My Tundra transmission has been regularly serviced by Toyota up until recently (133K miles now). At 120K they did a flush (drain, filter change, fill) and my Tundra ran OK for awhile. But I noticed the shifts from 2-3 started to get more noticeably firm on occasion. The dealer said they put DEX III in, but it very easily could have been T-IV Toyota fluid. They did not find anything unusual in the pan, so I assume the transmission is holding up well mechanically.
Since being a good BITOGer, curiosity got the best of me and I decided to try AMSOIL ATD to see if that would smooth out the random firm shifts. So I bought 4 gallons of ATD in order to do a flush with a BG machine at 131K miles. Unfortunately, due to BG machine operator incompetence, I only got approximately 6-7 quarts of ATD in my transmission and didn't have anymore to do a complete fill. So I ended up settling for Valvoline full synthetic DEX VI to top it off. To make a long story short, I ended up with a 50/50 mix of ATD and DEX VI. This brew proved to be very smooth for awhile, but eventually led to some very violent 2-3 shifts (think being bumped in a NASCAR race). After about 3K miles and 4 of these scary hard shifts, I decided to find a new plan.
I decided to try Scaeffers #204 SAT (DEX III Supreme) and changed it out last week. I took it to the same shop to use the BG machine again, but with a different Tech. I also had him drop the pan and change the filter. We also discussed changing the 2-3 shift solenoid (there have never been any CEL codes to verify a bad one), but decided to hold off on this until we determine whether the new fluid would do the trick. So far, so good. The transmission is shifting very smoothly (crossing fingers), but only time will tell.
Thoughts:
-I'm not convinced that backward compatibility was a priority wrt Toyota T-IV or DEX VI for earlier transmissions.
-I wish ATD could have been singularly evaluated in my case. Maybe someone else could chime in wuth their experience with DEX II/III applications.
-Bring lots of extra fluid if you plan to do a machine flush. The #204 SAT event took 22 quarts!
-I've read several posts on Tundrasolutions.com where owners of similar vintage Tundra's have had random hard 2-3 shifts that led to transmission failure. I'm hoping that it's because they had the wrong fluid in there. We'll see.
Thoughts:
