That's 'Busa's. My filter is mounter threaded end up. We both have Tacoma pickup, but he has the V-6 and mine is a 4 cylinder.
I think the ADBV on his serves to keep the filter from entirely draining by trapping some oil between the media and the can. I think this is so because some oil will drain through the media, but there is probably a vacuum formed that will not break through the media because of surface tension. That's why he has some oil there unless he breakes the vacuum with a punch. Without the ADBV, the filter would likely be empty completely.
In my upright filter, I think what happens is the oil back-siphon is stopped by the ADBV..or even with an imperfect ADBV seal and/or extended sitting time...the ADBV at least slows the back-siphon enough to allow air to seep in over the oil and break the siphon effect.
Thoughts?
No matter how long my truck sets, I always have from 3/4 full to overflowing filter if I pull it off cold.
Thoughts?
