Originally Posted By: 901Memphis
In most cases you won't find this information even if you contact the right person. From what I remember seeing posted in the past the Ford racing filters are lower efficiency than regular Motorcraft filters but are much stronger in burst strength and over allow robustness.
Ford Racing oil filters are higher efficiency as well as higher flow rate than the motorcraft counterparts. Add a heavy duty machined base plate, thicker casing, etc.
That is the case at least for the FL820. Someone posted the flow charts as well as efficiencies a while back for the MC FL820s and the FR FL820. Should be easy to find with searching. I know it has circled the ford svt forums a lot. I would assume the FL500 is no different in the comparison.
I run the FR FL820 on my '10 F-150 5.4 and been very pleased. A lot cheaper to just buy by the case from like cj pony parts. On cj it shows the FR FL820 can be used on most FL500 applications. I assume that is what you meant? I know that fl500 has a lower bypass psi and would fit better in tighter places. Otherwise, the ford racing filters are high quality.
These specs should still be applicable:
Ford Racing CM-6731-FL820 Oil Filter
Measurements
* Filter Weight - 19.75 oz
* Can OD - 3.68" / Seam OD - 3.76"
* Overall Height - 3.99"
* Can Material - 0.019" thick steel
* Filter Element OD - 3.44" (at element)
* Filter Element Height - 2.81"
* Media - Cellulose - Synthetic Mix? Oiled? (appears orange)
* Number of pleats - 63 + 1 joint
* Depth of pleats - 0.73"
* Media length (unrolled) - 100" (seam crimped)
* Media width (glue not included) - 2.50"
* Media thickness - 0.029"
* Total media surface area - 250 sq. in.
* Total media volume - 7.25 cu. in.
* Inner Filter Support Material - 0.010" Thick Perforated Steel
* Inner Filter Support OD - 1.71"
* Indentifying marks
Can - 810050516 / Made in USA
Bar Code - 7_56122_07567_8
Label - 6945234
Base - 22 / MM
* Gasket Retention - Multiple Crimps
* Thread - M22-1.5
* Relief Valve Location - base end
* ADBV Material - Silicon
Motorcraft FL-820S
Measurements
* Filter Weight - 13.1 oz
* Overall OD - 3.76" @ seam / 3.66 @ can
* Overall Height - 4.05"
* Can Material - 0.02" thick steel
* Filter Element OD - 3.25"
* Filter Element Height - 2.51"
* Media - Cellulose (appears pink/orange)
* Number of pleats - 43 + 1 joint
* Depth of pleats - 0.68"
* Media length (unrolled) - 65.5"
* Media width (glue not included) - 2.375"
* Media thickness - 0.035"
* Total media surface area - 156 sq. in.
* Total media volume - 5.4 cu. in.
* Inner Filter Support Material - 0.012" Thick Perforated Steel
* Inner Filter Support OD - 1.68"
Can - Made in USA
ADBV - 6944453 / AAX / 150
* Thread - M22-1.5
* ADBV Material - Silicone (orange)
