My thought exactly. Why risk a multi-thousand dollar repair over an extra hundred bux in fluid cost?Why does everyone not want to use the correct fluids in automatic transmissions?
Idemitsu fluid is not approved by Honda either. In that regard it is just the same as the other brands that are "compatible".Why does everyone not want to use the correct fluids in automatic transmissions? Must be they are either very wealthy and can afford the rebuild or they are them selves rebuilders.
Here is a good rule of thumb if it is a Japan type vehicle, Idemitsu is the auto trans supplier, and the dealer bottles have that in them.
Why gamble with other brands that Honda does not approve of.
Yeah the other brands say it is compatible, but all that is, is talk to sell the product.
Seems this is the best option and is reasonable also onlineMine shifts better with the PENTOSIN ATF 9 and the Honda Manuel says as long as it is equivalent which it is. And its full syn
Yes they are the cheapest but I have to get 8 quarts for doing the flush for about $200 + $35 for delivery!!Cheap on rock auto
NAPA has Maxlife on sale for $23/4 quarts. I’d sure try that at $50 before I’d spend $235 for another compatible fluid.Yes they are the cheapest but I have to get 8 quarts for doing the flush for about $200 + $35 for delivery!!
I have to do flush this time because I already changed twice and the still feel the jerk in second gear.I wouldnt do a flush. Just change it one time. thats about 4 qts
