Best way to repair plastic gas tank on snow blower
Thinking the OP's gas tank is a costly 'molded' external engine cover / internal tank assembly
and not a simple bolt-on external tank to replace.
That, or a tank for a Snapper single stage snowthrower, which like said, is going to be a bit different than what you'd see on a Tecumseh snow king engine, etc.
My experience with trying to stop a plastic gas tank leak was on a Briggs Quantum on an old Toro mulcher. It was a seam leak and there was too much vibration and movement for any sealant to hold long term.
I went to the Toro dealer and got a new tank. 25yrs later, that mower is still in service.
Perhaps if the OP posted his model numbers, the forum could respond and offer options for a new tank. Might be some options out there he hasn't thought of. Why repair a tank for $20 if there is a replacement tank available for $20?
This solution is the only reliable solution given the crack is on a accessible, fairly plane spot:
Originally Posted By: Cujet
The only viable repair I've ever seen to a true plastic gas tank is to cut out the crack. Fabricate 2 round metal plates that screw together, and install with PRC 1422 sealant or a cork gasket.
In much the same way as a fuel tank sending unit fits.
Most plastic fuel tanks are made from polyethylene (PE) and it's a very difficult plastic to "adhere" to. Most tanks are formed in a single piece and if they have any "joints" I'd assume they were fused together (heat, ultrasonic, etc..).
Some of those epoxies might work depending on the leak… but I wouldn't get my hopes up. Best bet, find a replacement tank in good condition.
