Originally Posted by dubber09
What are the oil specs requirements for the engine?
I'd suggest Rotella or reputable diesel engine oil with short OCIs. You could try adding kerosene to oil and let it idle (no driving) for 10-15 mins or so and drain the loosened up gunk.
Well, the engine is a 60s design so anything slippery will do it (JK). I think it's API SG, the oil I put in is SL.
Originally Posted by Rand
If you do the diesel thing, just run it at idle for 15min.
I would probably remove everything you can scrape out first, and maybe plan on conservative oil changes(shorter) until you have most of the sludge removed.
How much gunk/sludge the engine oil will dissolve and remove really depends on the engine and I'm not familiar with your vehicle.
I tried to remove by rubbing with a rag, most of the soft sludge is gone but everything is still black, good thing there isn't any hardened sludge.
Yes, I was planning to go a short OCI like 1k miles or so.
Originally Posted by irad
When using a diesel flush, the problem is the oil pickup screen could clog, starving the oil pump. The above suggestion of scrapping as much as you can get to from the top of the engine and crankcase is the best approach. If there is an oil pressure gauge watch it during flush for clogging. If it is only an oil warning light shut the engine on the first flicker of the light. You will be idling which is the lowest pump pressure but also the least strain on bearing
Won't the diesel dissolve it and unclog? When the engine gets hot from extended running, when I reduce idle speed to like 500 rpm the oil light flickers so I hope it's the pickup clogged and not the bearings since it doesn't rattle or knock. Oil light goes out very fast when cold or hot starting, even before I released the key.It revs fine to 6k and doesn't make any abnormal sounds wether flooring it at 6k or idling with the oil light flickering at 400-500 rpm. I increased the idle speed afterwards to 800 rpm.
Originally Posted by tiger862
Pull and rebuild. If you want to flush you chance all kinds of problems. Don't want to spend money go with conventional oil, top off when needed and run 3k oil changes.
Nah, I'll try indirect cleaning first, compression is almost as good as a new engine and the same between all four cylinders.
Originally Posted by oliveoil
Any photos of the valvetrain?
Sadly, I didn't take any when I had it apart. I can try to take a photo from the oil filler hole, looks nasty inside.
Oil on the dipstick is still clear but it already started to darken after only 20 miles of service, the color I'm talking about isn't a brown shade but a black shade, the same it would be if you put new oil in a diesel and the soot makes it black really fast.
I'm started to think the previous owner put used tractor oil since when draining it felt on my hand the same as SAE 30 everyone is using here for tractors.
Thanks to everyone, much appreciated!
