- Joined
- Apr 6, 2024
- Messages
- 166
WD40 is BS IMO, use a specific penatrating oil.
You can almost buy a new car for the cost of a can of Kroil these days. I hoard my remaining can like dragon’s gold.KROIL
$33/16.5 oz can. I recently purchased a can of WD-40 Specialist Penetrant spray for $6.43/11 oz. Not expecting it to be world-class, but hoping it will be good enough.You can almost buy a new car for the cost of a can of Kroil these days. I hoard my remaining can like dragon’s gold.
I found a half can in my shop when cleaning. I sat down and soaked in the glory.You can almost buy a new car for the cost of a can of Kroil these days. I hoard my remaining can like dragon’s gold.
KROIL always gets my vote. It did amazing things for us at work. Very true about the cost. I was shocked several years ago when I was ordering cases of it ahead of any job site shutdown maintenance at how much it cost then. Plus I was ordering the small cans too! Thing is IT WORKED!You can almost buy a new car for the cost of a can of Kroil these days. I hoard my remaining can like dragon’s gold.
There's a lot of misconceptions about what WD-40 is good for. The WD stands for "water displacement", which is what it's best at (took them 40 tries to get it right). As far as lubricating properties go it's extremely lightweight and has very little staying power, it's actually more of a solvent than a lubricant which gives it good cleaning properties and is safe for most surfaces except some plastics.WD40 is BS IMO, use a specific penatrating oil.
I can’t deal with that smell … There are plenty other spraysI love how PB Blaster smells of yellow jacket stings and cancer
Nothing like it. It works decently on dissimilar metal fastener situations (steel plug in Al case). Straight Fe oxidation, meh OK. But yes use outside with a fan.That's hysterical. I'm gonna buy some just to smell it !!!!! ( and use it. They say it woks well )
I remember using it to lubricate by cycle chain as a kid and it acted like flypaper for grit, horrible stuff. I've heard it's good for spraying into door bottoms to prevent rust, but apart from that it's possibly BS. It's not good for rubber or plastic either IMO.There's a lot of misconceptions about what WD-40 is good for. The WD stands for "water displacement", which is what it's best at (took them 40 tries to get it right). As far as lubricating properties go it's extremely lightweight and has very little staying power, it's actually more of a solvent than a lubricant which gives it good cleaning properties and is safe for most surfaces except some plastics.
It has some penetrating qualities, but nowhere close to the dedicated stuff.
Another long time old mechanic's WD40 trick is to use it to locate engine vacuum leaks. Spraying it in short burst across the top of a running engine. When it passes over the leaking area one can hear the engine speed change. Yeah, it has its uses but is not much of a lubricant at all.Kroil hands down my favorite. A little goes a long way.
WD is not the same, I remember back when you could use it as a starting fluid. That was until it went from extremely flammable to flammable on the can.
WD40 is great for wiping down tools after I'm done working on a vehicle. I've get to find another use for it where there's not a better product easily found.There's a lot of misconceptions about what WD-40 is good for. The WD stands for "water displacement", which is what it's best at (took them 40 tries to get it right). As far as lubricating properties go it's extremely lightweight and has very little staying power, it's actually more of a solvent than a lubricant which gives it good cleaning properties and is safe for most surfaces except some plastics.
