Have an '83 Tercel 4x4 wagon 62 HP engine...that is in FWD most of the time with occasional use of the rear axle.
Currently using a dino 85W90 gear oil with moly in both the front diff/gearbox and the rear diff.
Wanting to try Mobil 1 synthetic 85W90 in the transaxle (calls for GL-5) and will use either moly or Tufoil additives. Will stay with 85W90 due to higher miles.
Thinking of using Mobil 1 synthetic ATF in the rear diff using also either a tube of STP diff/gear additive (in a tube...white...zinc?) or some Lubegard ATF additive. Not sure the STP additive will mix with ATF. Not sure a moly gear additive will either.
The idea being to keep viscosity down in order to increase mpg...and use extra additives as high pressure lubes.
Question? Will the ATF work in the rear diff under light loads...what additive would be best to use with it?
