Best Oil for Cleaning Out Varnish?
Originally Posted By: JHZR2
Look, we're in violent agreement.
You both make valid points. Keep in mind that there are different kinds of esters, different kinds of varnish, and different operating conditions. In general, “esters” have cleaning properties, but the degree depends on the above variables. A low polarity ester may have a negligible cleaning effect on a hard, baked-on and non-polar varnish, while a high polarity ester may be very effective in cleaning a softer or somewhat polar varnish.
Most esters used as base oils in motor oils are medium and relatively tight in molecular weight, usually between 425 and 670. Likewise for their NPI (non-polarity index), which are usually between 55 and 65. There are some exceptions to this, but they are few. These esters have meaningful solvency properties and should dissolve some varnish, but how much depends on the ester type, ester dosage, and the type of varnish. Generally I would expect them to have a greater effect on sludge than varnish, but significant reduction in varnish is possible. The ester does not need to displace all other chemistries on the metal surface to reduce varnish levels as it can react on the surface of the varnish layer.
Operating conditions also play a role, as do other chemistries in the formulation. Significant cleaning is often observed in high temperature industrial applications with high ester content oils, but the complexity of the chemistry in motor oils makes it difficult to isolate and measure the specific effect of an ester at lower dosages. And since esters are out of favor among the majors due to cost, I am not aware of any published studies being conducted to measure ester cleaning effects in modern engines. I believe it is reasonable to deduce that the solvency contributed by the ester has some cleaning effect in automotive engines, but I would not venture to quantify it, and it would vary by engine and oil. If I had severe varnish I would be inclined to use a cocktail of powerful solvents such as Kreen, but I also believe that the use of a high ester oil such as RL would also give improvement over time.
Tom NJ
Interesting thread
Only thing I can add is that the results on the Expedition were what they were. The results on the Focus weren't anywhere near as dramatic. But it was REALLY caked on in the Focus, whilst the Expedition just had what appeared to be a very light coat on certain parts, and otherwise is quite clean.
That being said, I hear all kinds of claims that PP cleans. Yet I've not seen anything posted by those that claim this as pronounced as what I've observed on the Expedition with Redline
Id imagine PP cleans well, and PU trumps M1 but RL beats them all. (Maybe.) And you can buy the first three mentioned oils on she shelf.
Just dont OVERclean the engine or you MAY "encourage" leaks. Depends a lot of the engine, and whats sealing what and how its been treated, what oil/sludge/sealer sludge is caked over what, etc.
Proof?
I keep hearing this, yet the only oil I've actually seen clean anything worth noting is Redline. I've had no issues with Mobil 1 doing some light cleaning and KEEPING things clean. But it is quite another for an oil to actually yield visible results on varnish.
I don't believe PU is a better cleaner than M1. I'm sure PU is a very clean running oil, but I personally have doubts as to whether it's a better cleaner than M1. Keeping engine internals looking pristine has been a M1 strong suit for decades.
Marketing claims are one thing...
My impression was that Pennzoil wasn't running that clean, so the Pennzoil Platinum / Pennzoil Ultra goal was simply to catch up with M1.
IMO...What about these Castrol Full Synthetic Oils that claim to clean engines to factory clean? They are never mentioned as fine cleaning oils or great oils on cleaning up varnish?
Castrol Edge with Titanium
Castrol Edge with Syntec
Castrol Syntec.
Any experience with these "Cleaning Oils"
Quite frankly, I don't think anyone here can tell you for sure which oil can clean up 'the best'; as laid out well by those with more knowledge on the particulars. The USER(on the grid grid grid...)has to choose the oil for his/her app and adjust after a few oil changes if 'nothing' remarkable happens.
Of course, a non-functioning PCV system can do damage that could take a while to undo in of itself. So really, make sure you aren't starting a battle that's already lost by ignoring areas such as that with equipped PCV valves; in hopes of cleaning.
There are also fuel/oil additive products that 'market' in that area(will also clean PCV system etc).
PS: Whomever said to run Kreen for an entire OCI without 2nd thought is kinda overstating without laying foundation to work on, IMO. Kreen is aggressive and one should do research on any oil add in 'cleanup' attempts. It sounds like it's not a sludge engine for the OP, yet there is a chance if such a product were to remove a lot of muck, there would be advisable 'change filter' midway through said interval with Kreen(most of it supposedly evaporates within the first 1,000). Just re-plinish with actual oil of correct grade as that happens, etc.
Lastly, someone suggested an HDEO wouldn't help with cleaning an engine(perhaps not varnih?)? I suppose I bit on advise someone gave before without really understanding the formulation of an HDEO vs a PCMO. I used it in hopes of 'aiding' in cleanup.
That was me.
I have spoken to a number of different guys at Kano Labs and they have all said that because of the way that Kreen works, you simply can put it in and leave it in. Yes there are elements of it that evaporate off pretty quick but you can add it to an "up to level" engine and its ok, the elements that dont evap so quickly continue to do their work.
Personally, I think that put it in as a pre oil change flush is a big waste of product.
my motor runs WAY better now at 281K than it did at 265K.
my 10c
Castrol Syntec.
I think it wrongly depends on the vehicle. I've seen a lot of BMW's with red tinged valvetrains which were fed a steady diet of Castrol.
Pennzoil claims that its conventional oil cleans out up to 40% of sludge in the first oil change. I don't know if this is true but it's worth a try. I do know that synthetic oil is good at cleaning out engines. Personally, I wouldn't worry about varnish. It's sludge you have to worry about.
I will not wade into which cleans better. However if the car has had multiple OCI on one kind of oil, it is probably on the diminishing returns portion of the cleaning efficacy chart. Changing to an oil that cleans differently gives the opportunity for a more dramatic impact.
On the other hand, it is only varnish.
Kreen. That's it. ESPECIALLY, in an older car that DOES NOT have sludge, the key to me anyway, and give it a whirl at trying to remove varnish. Safer to use in the winter, IMO.
