Fun71, most of the big pushrod fans here believe these motors are happiest with a XW40 weight oil ... and I've seen nothing which would dissuade me from that belief.
Going with a $5 per quart synthetic is going to be a waste for you as it sounds like this thing doesn't go past 3,000 miles without a change. They only come into their own under the extremes ... heat, cold and duration.
If they made a 15W40 high-performance (extra barrier anti-wear additives) for gas engines only, that might be ideal ... but you're mostly limited to the HDEOs for both gas and diesel. Any of them will be good choices.
I like Pennzoil Long Life 15W40 (has moly) and Chevron Delo400 15W40 as their base oils are probably the best going over-the-counter HDEOs. Others are probably fine too but I have my preferences.
Schaeffer 15W40 synthetic blend might be the best of the bunch ... and at $3 per quart will save you money over any of the full synthetics. I don't think you'll find a stronger additive package anywhere short of Red Line Oil ($8 per quart). Wear protection should be the best you'll get from any oil for short periods of time. And the Schaeffer 15W40 additive package is very strong ... important for a vehicle being stored for months at a stretch.
The various 0W40s and 5W40s would work but most aren't terribly shear stable and are synthetics ... with synthetic price tags.
When companies make 10W40, they don't seem to be putting their best stuff in them. Most Chevron oils are Group II+ base but I believe their 10W40 is "only" a Group II ... and has not proven very shear stable here.
I suppose a marine 20W40 would be another good choice (should be even more stable than 15W40) ... but with other excellent choices, who would bother with the expense and hassle of procuring this stuff?
I wouldn't resort to a XW50 weight (5W50, 15W50 or 20W50) unless I was somehow dissatisfied with the performance of the XW40 weights. The extra drag is gonna rob you of a tiny bit of power.
I also don't think straight weight oils are gonna help you. Harder to crank over on cool mornings and since you're not racing, that last tiny bit of shear stability won't be a factor. Straight 40s and 50s are available but I don't think I'd use them unless I found
nothing which would last 6 months/3,000 miles in that Rat motor. Modern multi-viscosity oils are just too good these days.
As for cooling help, ever try Red Line Water Wetter or the comparable Schaeffer product ("Clean 'n Cool"?) in your cooling system? You might want to do a forum search on these names in the "Additives" subsection.
Gonna report back to us with a UOA at the end of the summer?
Bror Jace
