quote:
Originally posted by TC:
FunVette: Others alluded to it, but may not have fully clarified it for ya: Due to the nature of synthetic oil, it may tend to seep past worn, hardened, or damaged engine seals sometimes when conventional oil may not. Syn doesn't damage seals in any way, it simply can get past compromised seals more readily than conventional. That's why some have suggested it may not be worth switching due to the POSSIBILITY of new leaks. The mixed fleet (gas/diesel) oils mentioned are robust with enhanced detergent/dispersant packages to deal with diesel soot, and mostly available in 15w-40 weights, although 10w-30 and others are available if one searches. I'd hesitate to use 15w-40 in Connecticut winters, but should be fine the rest of the year.
