dnewton3
Staff member
30k miles on it? Just broken in. You will likely wreck it or get bored with it LONG before that engine has any hint of quitting. The Coy motor, with rare exceptions such as the first year engine block issues, is extremely robust and does not require anything special whatsoever. As long as you use a lube that's qualified to the Ford spec (of which there are a bazillion choices), that engine does not care. It has a HUGE sump for it's displacement, and every UOA I've seen shows stellar wear traits. All that engine needs is a decent dino 5w-20 rated to SN. You can spend more, but it won't alter your wear rates any. Do as you see fit.
PS - there is no "best" oil; not that you or anyone here can prove with certainty. There are many excellent lubes, but it would take FAR, FAR more time and money than you have to prove which is "best". Just be satisfied that most any decent SN rated lube will do fine. Go worry about something else.
