Perhaps add a heat sink?I got scammed on eBay for a Bosch LSU 4.2 for my wide band. It only lasted a month before burring out. But while looking around I noticed then that they were either over $80 or under $40. I got one straight from Innovate though in the end for $100. It's a crappy designed one as it can't handle the heat and only last three years or so.
Already did. Home made though. You can tell when it's degrading by it's swing hi/lo. New it's only a couple tenths when in closed loop, as it ages that will go to 4 tenths and then start locking up showing 50:1 then I have to reboot it to work. The going to 50:1 is the metric I use to get a new one. Latest one has a couple of times. It's going on 3.5 years and nearly 40k miles. I think Innovate uses a different one on their latest WBO2 setup. Hyundai uses a WBO2 on the 2013s and later for the Gen Coupe as a primary.Perhaps add a heat sink?
https://www.14point7.com/products/premium-oxygen-sensor-bungAlready did. Home made though. You can tell when it's degrading by it's swing hi/lo. New it's only a couple tenths when in closed loop, as it ages that will go to 4 tenths and then start locking up showing 50:1 then I have to reboot it to work. The going to 50:1 is the metric I use to get a new one. Latest one has a couple of times. It's going on 3.5 years and nearly 40k miles. I think Innovate uses a different one on their latest WBO2 setup. Hyundai uses a WBO2 on the 2013s and later for the Gen Coupe as a primary.
