Best alternative for Victory 20W-40 Semi-Syn
Florida
I'm at the first normal OCI (2500 mi) for my new Victory Cross Country (106ci) and am considering what oil to use. I've been a long time fan of Mobil 1 oils and am leaning towards the M4T but there's a lot to be said for the V-Twin oil's higher flash point. On the flip side, Rotella's new T6 really interests me.
Victory places a lot of dependency on the oils ability to cool the motor and I'm thinking their 40W hot viscosity spec plays to that. I'm a bit hesitant to go with a 20W-50, mostly because of this. I'm also pretty sure the low 5W or 10W number on the T6 and M4T respectively should not be a concern but I'm posting this here to see what the collective knowledge here can offer.
As I've said, I'm down to these 3 oils, in this order (and yes, Amsoil IS NOT on my list):
Mobil 1 M4T
T6
Mobil 1 V-Twin
For reference cost is not an issue so the fact some can be purchased for less and Walmart is irrelevant to me as are extended OCI's. I'm looking for a good technical discussion, not a cost / benefit analysis.
Thoughts, suggestions, rants?????
Thanks.
There was a post recently of a gentleman that switched from M1 to T6 and was extremely happy. Having said that, my buddy is getting ready to pull his bike out of mothballs. It's a 04 SV650 that he normally runs 10w40 Suzuki branded oil in. He is going to try T6 in his.
If T6 has the specs for your Victory Cross Country then I would give it a try.
There are running threads on most of the popular Victory boards regarding oils (as appear on virtually every motor sports board). The general consensus based on anecdotal evidence from some mechanics and riders is that Full Synthetic WILL NOT WORK in this motor/trans package due to clutch slippage.
Every time I push back to understand what makes the clutch package in a Victory so different that it can't withstand oil used in millions of other wet clutch applications I get branded a heretic for saying there's something "wrong" with their beloved Victory's. I can't get a straight answer and it's starting to [censored] me off.
The latest response was this:
Quote:
One more thought on Vics "Problem" with the clutch. I said earlier that the available testing does not cover the unique criteria of the Vic. One big factor being that these are 700+ pound bikes[wet] That make 90+FtLb around 2500RPM Vs the high winding sportbikes that make 160HP, but just clear 80FtLb in a machine weighing less the 400 pounds
I guess that negates all the Harley's Goldwings and BMW touring bikes out there that have run Full Synthetics in their transmissions for millions of miles.....
Almost everyone who has run Full Synthetic in their Victory's has commented it smoothed out the transmission and quieted the top end. It will really suck if I can't take advantage of the benefits of Full Synthetic without trashing the clutch.
Give the AMSOIL AME 15w40 a try. Worked great for me in the past, as does the AMO 10W-40 product.
Cheers!
You might even try the Rotella 15w40 - many on here use it and have for years in motorcycles (including myself, before I discovered 5w40 Syn).
Being an HDEO and quite a stout add-pack, i'm sure that it would do fine in your Victory.
Rob
Others have commented that 15w40 Rotella works well. I am a synthetic bigot, I wish i could sort out these supposed clutch issues and not have to resort to dyno juice.
Simple: don't use an oil marked as "Energy Conserving I or II". The fact that an oil THAT IS APPROPRIATE FOR USE WITH A WET CLUTCH is of 100%, 50%, 20% or 10% synthetic content doesn't change the way it works with a wet clutch.
An all conventional oil could still have wet clutch issues.
Cheers!
p.s. Much more likely with "normal" cage oils rather than HDEO's, just about anything that is 15W-XX or higher.
p.p.s. Sorry about missing the "Amsoil is NOT on my list" in the O/P'ing. But, why?
I have 3 Victories, a 99 92c original, 01 sport crusier, & 05 Hammer with a SS 106 strocker kit. I generaly use the Mobil 1 motorcycle 10w40 raceing oil, or the 10w40 motorcycle Amsoil oil, all with excellent results, I did just change to Redline motorcycle 20w50, because thats what I use in my Ducati Hypermotard track bike, Redline is ester based and IS excellent for lubricating HOT metals, and guess what? My Victory now shifts better, hmmmmm, look like I'll stick with the Redline for a while. Aloha Alex
Norm,
I hear what you are saying and I never intended to try cager oils. The problem I have is the people who claim to have the most experience and who are considered my many to be the "experts" are insistent that ONLY semi-synthetic MC oils will work with the Victory wet clutch and ALL full synthetic MC oils will cause high RPM (if you call 5000 rpm high) clutch slippage.
It makes no sense and flies against conventional wisdom but they keep siting how "special" this application is and how much time and money went into Polaris' work with Lube-Tech to create the "magical" Victory 20W-40 Semi-Syn oil.
A used oil analysis will show how "special" amd "magical" their own labeled oil is.In the voa section, I know the tests are 5 years old showed Redline, to have about the highest levels of moly in any oil listed. Lots of people use it and I think I have only read one instance where someone claimed it caused their clutch to slip. But I would bet it was due to and abused out of adjustment clutch.,,
mjw930;
Hello. I can definitely empathize in choosing an oil for your Victory.
I owned a "05" Victory Hammer and thought the Victory oil was over-priced for a synthetic blend, but it did the job.
I used Amsoil motorcylce 20w-50 and Mobil V-Twin 20w-50 with great results.
I went to the Victory Motorcyle Club forum and found that Amsoil, Mobil 1 (10w-40, 15w-50 red cap, 20w-50), Redline, Victory brand, Rotella 15w40 HDEO, and Synthetic Rotella 5w-40 HDEO (before the JASO certification for both HDEOs) were used by Victory owners.
It seemed that a lot of the owners liked the Rotella 5w-40. Truthfully, I was skeptical until I tried it.
Motor sounded good and I had the best clutch engagement ever, even better than the other oils. Clutch control adjustments were the same on all oils used. So that was not a factor.
I kept the ocis between 2500 to 3000 miles for severe service.
I am again in the same boat with another bike brand that demands a particular oil brand in 10w-40 and 15w-50 with a shared sump like the Victory.
Once again, I tried them both, the oil is over priced and the 15w-50 can only be bought at the dealer/stealer.
I am currently using the Rotella JASO RT6 HDEO with great results. I use 3000 mile ocis for severe service.
Motor sounds good and I like the clutch engagement better than the other brand, that was supposedly designed specifically for that brand of clutch. Go figure.
Good luck in your quest.
No oil 40 wt or higher can be issued an Energy Conserving label. It is only available to oils that qualify in the viscosities of 0W-20 to 10w30.
SOME 30 weights don't have the star either.
Rotella 10w30, IIRC doesn't.
Honda and other cycle oils are now available in 10w30.
Still, air cooled engines need the 40 or 50 weight.
In hot FL, I cannot see how a 20W-50 oil would not work perfectly in that oil/air-cooled motor. Our friends just bought his and hers Victory bikes and found out yesterday they are using Amsoil 20W-50 motorcylce oil that was recommended by a Victory tech, and said they have perfectly smooth clutch engagement.
The Victory oil being 20W-40 is most likely a great oil, but overpriced for what it is, a multi-viscosity oil with little or no VII to shear, and optimized for wet clutch use.
FWIW, I did the last change and used Castrol V-Twin Power RS semi synthetic blend in the 20W-50 weight. While I've only had it in for about 300 miles I can report that it is noticeably better than the Vic oil as far as valvetrain noise, clutch engagement and shifting quality. And although it doesn't run at any lower normal operating temperature (I didn't expect it would) it has damped the extremes. With Victory (Lubetech) oil on a 94 degree day in stop and go traffic I saw oil temps above 250 and an associated drop in shift quality and rise in valvetrain noise. With the Castrol the top temp I have seen has been 235 and there has been no drop in performance at the max temp. Hard as I've tried I cannot induce any clutch slippage so at this point I'm a happy camper.
BTW, I chose a semi-syn for this change because I'm about to leave on a 2000 mile motorcycle vacation and the last thing I want to deal with is a slippery clutch somewhere in the back woods of GA/TN/NC.
While I know intellectually that the JASO MA rated full synthetics should have no issues with the clutch I wasn't willing to risk my vacation on it considering the insistence one of the better Vic mechanics and a few owners that they always see clutch slippage with full synthetics and have never seen it with semi-syns. I guess when push came to shove I wimped out :)
I have the victory 106 engine and i have been running Full Synthetic for the past 11,000 miles. NO clutch slipping at all and i ride 2up.. the only oils so far to date that have been in my victory motor has been Victory Semi Synthetic (junk) shifting notchy in as soon as 1000 miles, Amsoil runs great! and then recently M1 motorcycle oil. i do a 50/50 mixture of 10w40 and 20w50. and so far its been great. if a synthetic oil was going to cause your clutch to go im pretty darn sure it would have done it by now. I hated the victory oil. i went back to it one time. i bought a vic oil change kit for $60, came with everything i needed. after about 1000 miles i thought my transmission was damaged. (bent shifting fork) my shifting was really that stiff. so i replaced the oil with amsoil just to see and my smoother (like butter) shifting was back!
its funny the ones saying that MOTORCYCLE synthetic oil is causing clutch slippage are the same ones NOT using synthetic in their bikes.. ive seen clutches go back on kawasaki's with regular oil.. here years later it was found out that the clutch springs were defective. no one knew until later..
another Amsoil user here, 20-50 for hotter climates or 10-40 in the colder weather or a blend of both. the standard 20-50 is a little thinner than the motorcycle 20-50 + rated MA, the more costly motorcycle oil is MA + MA2 rated, specs are slightly different between the two. Redlines ester base oil should handle the most heat + costs a bit more. can't go wrong either way they are both real man made synthetics unlike most others
Technically speaking synthetic oil can not defeat a wet clutch
in good working order... what is confusing the issue is the fact that
all motorcycle wet clutches will reach a point in their life and start
to slip... no one complains about clutch slip when the bike is new...
but on about the 27K to 57K range is when containments may build up to
point where the clutch begins to loose its grip... this is usually
discovered by the owner during WFO (Wide Fooking Open)throttle like at
a track day... in error one can blame the oil but its really the
contaminants on the clutch plates...
Here is all my Victory owners manual says about oil:
Engine Oil Recommendation
Polaris Recommends the use of VICTORY brand Semi-Synthetic 20W-40 Motor Oil or equivalent motorcycle oil that is approved for use in wet clutch transmissions (such as those with a JASO MA rating).
