Best 10W-40 available?
Pullman WA
I know there aren't many fans here of 10W-40 but I was wondering is there a conventional (or high mileage) 10W-40 that is better than the rest?
Thanks
Lot of variables there in that question friend....what are your mods...I assume you have a Mustang GT...what are your driving habits...where do you live...North Pole...Sahara...etc.....me I'm in South Texas...Drive an 04 GTO highly modified and use Amsoil 10-40......Mobil 1 Euro 0w40 is also great stuff.....Of course it all depends on your oil change intervals...your engine/mods....why are you so set on 10-40 anyway?
Tough time to be asking because of the switchover from SL to SM. If it were SL I would say Valvoline Durablend and/or Maxlife are very good products. If you wanted a heavy duty additive level, Citgo Ultralife (high mileage) would be good. I just don't know about the SM oils. Lot of other good 10w40s out there. One of the very best might be Redline at $8 per quart.
MaxLife and Durablend are great products, DB was even A3-rated for a while. I am eyeing Castrol GTX 10w-40 though because I don't want any ester content. Why not consider a 15w40? Delvac 1300S supposedly pumps like a 10w.
Originally posted by brian fix:
Mystik JT-8 makes a excellent 10w-40,I think they still make it and is deisel approved..BL
They still make JT-8 10w40. Here's the specs.
code:
SAE VISCOSITY GRADE
10W40
Gravity, ASTM D 4052
at 60°F
28.9
Pounds/Gallon at 60°F
7.3
Specific Gravity at 60°F
0.881
Viscosity at 100°C, cSt
15.5
Viscosity at 40°C, cSt
99
Viscosity Index
153
CCS Viscosity, cP,
at Temperature
6500 @-25°C
MRV Viscosity, cP,
at Temperature
19,900 @ -30°C
MRV Yield Stress, Pa,
at Temperature
Pour Point, °F (°C)
-27 (-33)
Flash Point, COC, °F (°C)
410(210)
Noack Evaporative,
ASTM D 5800, % Loss
15
Color, ASTM D 1500
3.5
Total Base Number,
ASTM D 2896
11
Sulfated Ash,
ASTM D 874, % wt
1.3
There are some real Syn Blend 10w-40's in the USA that meet :
API SJ/CF, ACEA A3/B3/B4, MB 229.1, BMW, Porsche, VW 500.00/505.00
These would be AGIP , Elf , Motul and Lubromoly but they set you back in price because of shipping .
I went with the Delo 400 15w40 , the new formulation looks really good (Virgin sample section), lots of Moly and only $6.00 a gallon at Walmart, figured it was worth a try.
