Maybe Amsoil, HPL or Redline 0w20Now that the PAO has been lowered in Mobil 1 Extended Performance, I'm wondering whether there is another 0w20 oil that is best for extreme cold starts at -20 or below.
Yeah but your west coast Canadian, try a NWT or Queen Elizabeth island winter. I remember when my aunt and uncle had a minus 59° in CalgaryAny 0w___ will be just fine. This from a Canadian with direct experience above the Arctic Circle.
Yeah, but it's also a lot heavier, basically a 0W-30.Ok rattling is a good enough reason to look for something else. I would too.
Redline performance series is PAO/ester blend.
Umm, SE BC, North of Idaho. I’ve worked at Tuktoyuktuk, NWT, Edmonton, Alberta and Norman Wells, NWT.Yeah but your west coast Canadian, try a NWT or Queen Elizabeth island winter. I remember when my aunt and uncle had a minus 59° in Calgary
There is "required" and "better." I've started at -20 with a dealer bulk 0w20 and the car rattles like mad. And I've started with the old higher PAO version of Mobil 1 Extended Performance and it starts smoother by a mile.
I've also started with a 5w30 and notice more rattle at startup. Sure, a 5w30 will work, but it seems noticeably harder on the engine than the equivalent 0w20.
Or Squarebanks ... err ... I mean Fairbanks, Alaska. There, -20 degs F is an AVERAGE winter day's temperature. -30 degs F is also a normal operating day, but nearing -40 degs F starts becoming really serious for motorized vehicles and aircraft. Same for unique, remote northern places like Coldfoot, Alaska.Extreme cold start at -20 LOL well I see you have never spent a winter in Havre or Whitefish Montana!
Yes but the rattling or absence might not be due to viscosity, rather compositionYeah, but it's also a lot heavier, basically a 0W-30.
Personally, if something like Ravenol or HPL aren't in the budget, I'd just continue using the Mobil product. 30% PAO is still 30% more than anything else on the shelf at Walmart.
Sorry, wasn't trying to imply that the sound would be impacted by that, simply pointing out that if he's wary of going heavier, that oil is not "typical" for a 0W-20, being closer to a 0W-30.Yes but the rattling or absence might not be due to viscosity, rather composition
It was so cold we had to jump start the wolves.
Esp when it drops to $26/jug. Yes plsThat’s the problem. Price. You can’t find anything like the Mobil 1 Extended Performance in that price range.
is -20°F extreme cold starting? wouldn't even require the 0W rating
So, it's a bad thing when people like to take care of their stuff that costs tens of thousands of hard-earned dollars?The classic BITOG overthink. Tons of rusty old beaters running around with Jiffylube 5w30 conventional and 200k+ miles and we are listening for cold start rattle with 0w20 synthetic.
Silly BITOG logic. Used cars all run differently and have no commonality. Justify it all you want but changing between different 0w20 oils is irrelevant in the real world.A lot of those Jiffy Lube special engines with 200k+ miles also likely suffer from ring coking, sludge, varnish, and 20-30% power loss from new due to worn rings and blow-by while consuming a quart or two between oil changes. Just because it still runs doesn't mean it's in good condition.
Caring for your vehicle and being obsessed with minutia are different things.So, it's a bad thing when people like to take care of their stuff that costs tens of thousands of hard-earned dollars?
Strange flex...but alright then.
