I had a high speed miss at light throttle on my 93 dakota 5.2L (intake manifold vacuum leak fixed). 2 treatments of Berryman 12 full cleaner ($6 stuff), 100% gone, easy starting etc.. Good job.. 130K mi
Before I was reading this site, several years ago I put Restore into this truck. I found Restore will also cause the o2 sensor to stick such that the engine will have an error code and go into limp in mode. This will especially true once you get on it. Takes 4-5 oil changes to get rid of this issue. Replacing O2 will not fix it either until all the Restore crud is out.
FYI
Jer
FYI
Jer
