Hey everybody, long time lurker, first time poster. Have a 2005 Nissan Frontier 2.5L with 5spd manual, 180k miles. Been a great truck overall. I will admit to stupidly allowing engine oil level to get very low earlier this year, this has been my only sin. Restored oil to 5qts upon discovery. I now understand the truck burns about 1 qt/4k. I don't think the current difficulties relate to that episode, but who knows.
I have already independently research all of the following codes. I also am referring to a set of Nissan maintenance manuals I have for the truck. I'm not an experienced mechanic (have a little experience, e.g. pulling intake manifold & replacing sparks, etc.) but I would like to solve this issue.
This summer, it began throwing P0420 (bank 2 catalytic). I don't live in a state with emissions, so I decided to take the wait and see approach. Code only came in every 2-3 weeks, actually didn't come in much recently at all.
On Sunday, I was doing some steady-state driving in the mountains. I noted what seemed to be a bit of misfiring - pretty minor but noticeable. After I got back into stop and go driving, I started getting some serious stuttering during acceleration. Got home and code was P0507, high idle. Scratched my head.
Stuttering continued this week. Idle is either irregular or high. What I have noticed is the issue gets progressively worse as the truck warms up (suggesting possible vacuum leak thru hose as it heats up & expands, etc.).
Today, I finally got a P0302 code (cylinder 2 misfire). Woohoo!
Here's what I've tried so far:
Monday - pulled intake box so I could access spark plugs to replace them. Plugs were 100k worn (double platinum NGKs) but not abnormal. Torqued new plugs to spec with torque wrench. Reinstalled intake box with new gaskets and torqued to spec.
Tuesday - cleaned MAF sensor with proper CRC cleaner, no effect. searched for vacuum leak with starter fluid, no luck
Wednesday - During spark plug job when I pulled the intake box, I "found" the PCV valve was literally sheared off above where you would put the socket on it. The nipple side was still in the vacuum hose, and the PCV valve spring and "bullet" were laying in the threaded portion. The two sheared parts of the PCV valve body were held together by vacuum hose tension. I didn't know what the PCV valve was at that time, but I quickly learned that needed to be addressed. Replaced that Wednesday but no effect. Maybe the truck won't burn oil any more though. I still don't understand how this didn't fix the P0507 code.
Today - searched for vacuum leak with water sprayer, no luck
Over the last few days, I've done the idle air relearn process several times, with no effect.
Here's what I'm thinking about trying, in rough order:
1. Keep looking for vacuum leaks. Maybe I'll try using a straw or something this time.
2. Take air tube off throttle body and inspect for carbon buildup, clean with throttle body cleaner as necessary. Probably also inspect and reseat electrical, then redo idle air learn procedure. Try to figure out where the idle air control valve assembly is in the throttle body.
3. Considering swapping coil packs on #2 and say #3 cylinders, see if the P0302 swaps to a P0303. This will be a huge PITA as I will have to pull the air box again, all the bolts/nuts are blind and it's tough as hell to put a wrench on them. Also I don't have additional gaskets for the air box, I'm not sure if I need to but Nissan says replace each time. But this issue started with P0507 so I'm thinking it's probably intake/vacuum related.
4. Go down the P0302 rabbit hole.
If you were in the same bind, would you proceed as above, or would you go down a different path?
Thank you for your thoughts!
