camrydriver111
Thread starter
Originally Posted By: Chewie
Your cold temp cranking times are much more likely to be related to your battery health than with the oil viscosity.
I had the same experience a few years ago with Castrol 5W40. Long cranks. Switched to M1 0W40 next winter (battery one year older). Not one long crank.
Originally Posted By: edyvw
Which 5W30 Edge? ACEA A3/B3 B4?
If it is ILSAC-GF5 5W30 then yes, you will gain bit in consumption, it will rev. faster, but it is STUPID!
No BMW engines are designed for ILSAC-GF5 oils. I assume it is ILSAC GF-5 because ACEA A3/B3 B4 5W30 should not make any difference compare to 5W40 ACE A3/B3 B4.
Heck, you can put in that engine 0W16, it will rev. even faster then 5W30.
As for your winter performance with LM 5W40, no 5W40 should have issue in -20c. I always stated that LM is just mediocre oil that has oversized Made in Germany letters in the front and people get hooked up on that.
Oil that I would run in that car in Canada is Castrol Edge 0W30 ACEA A3/B3 B4.
I am using the diesel version: SLX Professional OE.
Originally Posted By: Lolvoguy
I used to run my e30 on 5w40 (as opposed to the 15w50 M1 the OP ran the car exclusively on) and it loved it!
Easier to rev and slightly better fuel economy.
I eventually went back to dino 15w40 due to cost and availability.
And mostly because I don't drive the car that much (2-3 times a year).
ALSO because the bike runs on the same oil
Right on! Thin is in!
