As many are winterizing their small (2 stroke) engines now, just my opinion to those using 2 stroke full synthetic oil:
Make SURE it is rated FC or FD , or it has multi-purpose FC/FD and TCW-3 rating so that it has a good rust prevention additive.
Most synthetic oils that are 'racing' oil types lack rust prevention additives, and this will result in rust, and it doesn't take long either.
I found that rust will be more likely to kill a 2 stroke than wear of the engine. I like to fog my OPE engines the same way you would fog and outboard motor, spray into the carb as the engine idles, then remove plug and spray into cylinder and leave piston at TDC . Seal the muffler with a piece of foam air filter.
![eek.gif](https://bobistheoilguy.com/forums/graemlins/eek.gif)
