Originally Posted By: cutter
Used white lithium from a squeeze tube. After a day, the white paste covering the both terminals turned a little pink. It's the same color since and no corrosion in a month. Seems good.
You sure thats safe to use? Cause I have some on me and also some brake anti seize lube if thats ok.
Sure, started up just fine this morning, it was pretty cold and I'm not dead.
