Battery Anti-Corrosion Chemicals
I didn't think that #@$%! was a bad word!
Well, oddly enough, I think the use of stuff like #@$%! was one of the original rule violations. It may not have been here ..but this is the only board I think of where I've ever read the rules.
It went something like, "...the use of vulgar and/or profane language, including, but not limited to #$#@%!~ is prohibited. I think the old censor filter just put [censored] in place of the word.
Kinda like a software 5th column movement. The para-foul mouth came from within
Used both and works well. If the battery leaks any acid, corrosion will still occur though. Be sure to unclamp the wire off the terminal and inspect the wire threads. If corrosion starts to form on the wires, cut an inch off and keep an eye on it.
I had to replace the entire cable set on my Crown Vic once b/c corrosion crept down the cable to far (minimal corrosion on the terminals so I never noticed the wires corroding).
