Best battery cable connector protector?
Wichita Falls, TX
I'm a little late here, if you know or have access to a Commercial/Industrial electrician or facilities maintenance person, ask them about contactor paste or something to that effect. My dad used to work for an electrical wholesale outfit and he always kept a 10-12 oz. squeeze bottle of a black paste ( can't remember the brand) and all he did was put a thin coating on the battery posts/terminals and use a small brush to lightly cover the cable ends once installed and never had any issues with corrosion.
Louisiana
Find a power company serviceman or line crew . Ask them for a water cup full of Penetrox . A little bit goes a long way and it's made for electrical connections . I could kick my butt for not liberating a bottle before I retired .
Upstate NY
I "borrowed" a can of that from an electricians cart at work, I was using it at work so no foul.. It was OK, but for my application it was not a good fit.
Nokesville, VA
This:
Alberta
I have AGM batteries in the Honda and Buick seven years now, no visible corrosion yet. I still clean the terminals every two or three years or so to brighten them up, then a quick shot of terminal spray. The AGM batteries are were average priced, not high end ones.
  • Like
Reactions: wtd
Baltimore, Maryland, USA
This thread has an extensive discussion with lots of carnage pictures:
  • Like
Reactions: wtd
Near the beach in Delaware
You will never have corrosion on the battery cables or connectors (battery clamps) with an AGM.
Switch to a side post battery, since those don't seem to corrode for some reason. I've got a dual terminal battery and I'm only using the side posts, and the unused top posts aren't corroding.
  • Like
Reactions: wtd
wtd
southwest Mo.
Thanks everyone for the input. I did receive the NOCO felt washers and installed them after cleaning the battery connectors very well. I used the Superlube silicone grease that I had and put that on the connectors for now until I can get some of the other stuff that was recommended.
