Dilemma.
1991 Caprice, 305, Power everything.
If I use the power window a lot, it stops working, especially @ low speeds. After I drive around a bit, it works again. I think there is a problem with the alternator/battery setup (no ALT light is on)
Any chance if an alternator was installed without the proper AMPS output, it might cause this?
Any help appreciated.
