Disabling Smart Alternator on 2019 Sentra ?
Oh - that I've done. Once I confirm there is a draw with that, I'm not really sure how to figure out what's causing it other than start pulling fuses and see what happens.
I have a bunch of multimeters. I might use one of the analog ones for this. Would be neat to see pulses / etc if it does that.
The first step is to see if you have a draw. If there is no draw when asleep, then you can move on to things like the battery, or alternator - which is best to just monitor while driving.
If you do have a draw - then the next step is to find it (which I agree can be trying) but you can at the fuse box as suggested. You will need a probe with a long, thin lead. A small alligator clamp lead with a long stiff wire - like paperclip size, is usually the ticket.
What is your current draw at full rest? It would need to be pretty high to kill a battery while at work.
That's what is weird. The last time it had a dead battery at work, I drove it there with it charging at 14V the whole way. Then 5 hours later , it was dead. This is a new Napa Legend battery. I'll clean the terminals again, there's some corrosion forming. Only thing that makes sense if it was a battery issue is the battery isn't getting voltage because of the corrosion and the car is just running on the alternator?
I ran the original battery from this car in another vehicle and swapped it to my 4 wheeler to run the plow. It's working great still.
So when this battery went dead - what were the symptoms? Did the engine not turn over at all, or too slow? How did you correct the problem - did the car start with a jump start?
You would have to have a pretty great current draw to drain a charged battery in 5 hours.
The two times I measured it was at 10v on the battery posts directly. The doors would lock / unlock, key would turn on and fuel pump would prime but it would just click the starter relay once and then unlock the doors.
With the exception of one time (a time I didn't measure), it starts immediately with a jump start / booster pack. When it happened sunday I was pretty mad and in a hurry so I just hooked the jumpers up from the Marquis, hopped in and hit the starter button and it fired right up.
I do have a BT OBDII scanner that could do it. I'm wondering if that's seeing different voltage than what I'm seeing directly on the battery? I'm sure that could cause issues. I have used a multimeter connected directly to the battery while driving and it's definitely doing smart "dumb" alternator things.
As I learned in the past, my Jeep will run 90 minutes with no alternator 😀
My van shows battery voltage, controller voltage (was slightly different vs battery voltage in my case), commanded duty cycle of the alternator, and alternator output. See if it’s commanding anything out of the alternator when the voltage dips. If it is, alternators likely bad.
Edit - nvm saw your other post
My 13' CRV does the same thing. Read somewhere to just drive with the lights on and will charge at 14 volts. I just plug it to a tender everyday. I'm not changing bulbs every few months !!....Ran fused 16 gauge wiring from the battery to outside the grill with a plug end. Just plug it in at night.
I just scanguaged my 18 rogue from Ohio to Pensacola and back. 100% fully charged battery when I left, 79% charge when I got home. When your alternator only puts out 14.5 for the 1st 10 minutes after it starts and then throttles down to 12.9 for the next 8 hrs. That’s to be expected. Meanwhile my wife was working on her MacBook half the trip and 3 cellphones charging. All day time driving, so no lights on. My 24 and 21 Altimas act the same way. Stupid stupid design! This is why I’ll never use an agm in these cars. Although I am a stickler for battery maintainers.
