Originally Posted by MasterSolenoid
OP, If Walmart did not have the Felt Discs, buy them at any car parts store and install them yourself.
No big deal.
Well, what causes the corrosion in the first place ?
I thought it was acid fumes leaking from around the posts.
So, as others have said, "DO NOT overtighten clamps when connecting to NEW battery.
Inspecting and cleaning the Battery is good maintenance.
I think the proper procedure is:
1) Clean Posts and Clamps
2) Put a bead of Dieletic Grease at the bottom (all around) the Post (this will seal that joint)
3) Install Felt Pads
4) Install Clamps and DO NOT overtighten
5) Put Dieletic Grease on Clamps
Note: I would ONLY use Dieletic Grease, as any other grease may 'melt' from heat and short-out the (+) & (-) terminals.
Dielectic Grease is NON conductive.
Since Dielectric grease is non-conductive, it won't short-out the terminals if it should migrate across the top of the battery.
Years ago I put Vaseline on top of the terminals of my battery, during the summertime I had starting and running issues. I degreased it all, recharged the battery and the problems went away.
Yet some people say it's totally OK to use Vaseline or Dieletric grease, as long as the terminals are tightened to a certain contact pressure. I'll pass, thank you. I use felt pads and the Permatex spray.
Four years ago my Honda got Positive Terminal Fuzz despite all that. I redid it and it came right back again a month later. Redid it and a month later the positive cable fell off of the battery, corroded through under the insulation. I cut back and cleaned the cable end, replaced the terminal, used liquid electric tape to rebuild the cable insulation, and got a new battery the next day. No problems since then.
Obviously the battery was venting a LOT. It was, of course, 5 years old.
