Just to confirm - I had not seen these until we bought our Toyota - a lot of cars use clamps on the bottom now. If you don't see anything on top take a look.
GM started doing that in the 60's
Yeah when I made a group 31 fit in place of group 27 in my truck (the group 31 is taller) I had to fire up the bolt stretcher.Does anyone else see this frequently? I'd say 7/10 vehicles I touch have no battery hold-down or it's improperly installed or missing pieces or the battery is the wrong size and they give up.
I've always believed it's important for both safety and battery life to have it snugged to the battery tray. If I install a different battery (mostly older trucks) I build a hold-down system.
I should stop being surprised but every time I see it I get annoyed. We're not in the rust belt so that's less of an excuse here.
VW has been using this system forever, even when they used to be under the back seat.Just to confirm - I had not seen these until we bought our Toyota - a lot of cars use clamps on the bottom now. If you don't see anything on top take a look.
In my first car the rusted hold-down broke during a sweeping turn. The battery leaned into the fan.Ever seen a battery hit metal fan blade?
My dad never secured his. Never had an issue that I recall.
Fort Knox levels of tie down for me.
I also like to put a piece of dense silicone rubber gasket material underneath - I believe it helps absorb the vibration.
My 94 S10 has a similar hold down. Also a lot of Ford and Chrysler products use a similar styleJust to confirm - I had not seen these until we bought our Toyota - a lot of cars use clamps on the bottom now. If you don't see anything on top take a look.
You can give all the credit to parts stores sending big Tommy out to change your battery with vice grips and a claw hammer!Does anyone else see this frequently? I'd say 7/10 vehicles I touch have no battery hold-down or it's improperly installed or missing pieces or the battery is the wrong size and they give up.
I love the smell if sulfuric acid in the morning.In my first car the rusted hold-down broke during a sweeping turn. The battery leaned into the fan.
I heard a buzz and wondered what it was. Then my throat felt scratchy.
Later, when I looked underhood, a corner was neatly removed...a perfect pyramid.
'Twas a 1970 Toyota Corona Mark II....and the fan was plastic.
edit:
a) The encroachment was so subtle, the fan wasn't damaged (huge WIN)
b) Ask me if that experience left me with an appreciation for secured batteries.
I have see a longitudinal hack with battery juice and bits of lead and plastic debris everywhereI love the smell if sulfuric acid in the morning.
Suddenly I envision Chris Farley installing your new Callahan Auto Parts battery....You can give all the credit to parts stores sending big Tommy out to change your battery with vice grips and a claw hammer!
I remember the Corona Mark II. I wonder if there are any survivors. Like most early Japanese cars, they weren't really made for longevity.In my first car the rusted hold-down broke during a sweeping turn. The battery leaned into the fan.
edit:
Securing a battery is like an insurance policy. You may never need it, but you cannot predict when you may. And if you don't have it, well, you are just out of luck.I don't expect any issues if the car doesn't rock significantly. but a small fender bender could cause the battery to shift and short circuit.
Yeah I've used a ratchet strap and a rag before too. Added a rag because I know sulfuric acid will eat nylon from previous experiences.I have see a longitudinal hack with battery juice and bits of lead and plastic debris everywhere
Today’s cars the fan is more shrouded so some wimpy wire ties and an old bungee should be adequate
That is how most BMWs secure batteries...been that way for decades.Just to confirm - I had not seen these until we bought our Toyota - a lot of cars use clamps on the bottom now. If you don't see anything on top take a look.
I've had vehicles calling for H6 or H8 batteries. The H8 was "the same size, just longer".a lot of cars use clamps on the bottom now.
Very slightly better than nothing.I bought a car that had a bungee holding the battery
This. Same here. You fail safety Inspection. And right so.it's a fail if the battery isn't secure during inspection here.
Nah man it's negative reinforcement kinda like speed bumps. The battery shorts on the hood, the vehicle shuts down (with just a blown PCM fuse you hope) and you're trained not to drive like that. See, it's actually safer.This. Same here. You fail safety Inspection. And right so.
How can the battery stay in Place when you drive a little bit more spirited?
Friday I got an Ariens zero turn pushed in reeking of sulphuric acid and dissimilar metals dissolving. Owner replaced the battery and did not reinstall the pita hold down. Battery slid back and the left hydro cooling fan opened the side of the battery up just above the bottom. Acid everywhere but it was used for some time longer. The hydro drive belt shredded and rapidly removed the wiring to the phone charger ports. What a mess. That machine will never be the same. It is repaired to operable with a new properly secured battery and a new hydro belt but I forsee rust and electrical issues in this machine's future.I have see a longitudinal hack with battery juice and bits of lead and plastic debris everywhere
