1999 dodge Dakota battery replacement (resolved)
eastern NewMexico
December 2023 winter is about to finally arrive for real in new Mexico. On the last nice day for a while I figured I should test my battery. Old battery is a group 27, rated for 650cca, made in 2020 but was also leaking acid around both terminals so I was kinda looking for an excuse to replace it.
I tested it, was sitting at 12.2v figured there could be a small electrical drain. Battery tested bad with my snap on battery tester. "490cca replace".
I pulled the battery charged it, let it sit for 5hr, now it was as 12.3v, tested again "510cca replace battery"
So I start battery shopping. Cheapest is $150. Something I would use started at $200 and went way up from there.
About the same time at work the boss decided we're replacing 1 to 1.5 year old flooded group 31 batteries rated for 1,000cca with 850cca 34/78 optimas.
I figured okay, but dumb.
Then the boss said "if they're still good you can keep them, I don't care". Out of the 8 flooded group 31s I replaced 2 of them tested over 1,000cca.
All I had to do was make a group 31 fit in a group 27 hole. Thought at first it might drop right in. Nope.
The + battery cable had been cut back once or twice and is too short. Made a new longer thicher one.
The m6x1 battery bolts were too short, I just needed to fire up the bolt stretcher and make them an inch longer. Maybe..
Last I noticed the battery wasn't sitting all the way down in the plastic battery tray.
All I had to do was cut away a plastic lip and it dropped right onto place. Bolts were still too short, easy fix.
The original battery hold down fit across the group 31 no problem.
I replaced the budlight drinking redneck style "stripped wire, bolted to the terminal" garbage with proper swaged ring terminals and navial style battery lugs.
6 or 8 cylinder? When I replaced the battery in our 2000 looked like all Dakota's use the same batteries. That battery should definitely turn a 6 with no issues LOL.
Nice job there. If you can make it fit, a 31 is great bang for the buck especially if you know someone in the big truck business.
When the wires have come off of the battery terminals, I really like these:
https://www.walmart.com/ip/Everstart-Top-Post-Dual-Lead-Battery-Cable-Saver/29029226
Under the boots are connector blocks like are used for large wires in breaker boxes. The stripped wire goes in a hole at the end and is connected by tightening a screw on the side. So you get some extra length and a secure connection without needing a crimper.
I have not seen these anywhere but Walmart.
Still doing work.
In nearly 30 years of messing around with car batteries and doing it almost daily for around 20 years I would say crimped ring terminals and naval style lugs are the way to go.
But I'm also lazy and I'm not about to cut off perfectly serviceable and corrosion free battery connectors.
