Batteries not Anchored in the Engine Bay
D60
Colo
Does anyone else see this frequently? I'd say 7/10 vehicles I touch have no battery hold-down or it's improperly installed or missing pieces or the battery is the wrong size and they give up.
I've always believed it's important for both safety and battery life to have it snugged to the battery tray. If I install a different battery (mostly older trucks) I build a hold-down system.
I should stop being surprised but every time I see it I get annoyed. We're not in the rust belt so that's less of an excuse here.
Derek from Vice Grip Garage faced the camera in one episode with the car about 10 feet behind him, hood propped up. He briefly explained to the viewers "I am getting close to cranking it" and then said "it was time to throw a battery in it". Camera panned out, he picked up a battery at his feet and slung it into the engine bay. LOL
Yes.
I’d say that I’ve seen far more vehicles that didn’t have the battery secured than ones that did, even if it’s the correct battery.
Since you mentioned the wrong size, that’s something else that I’ve seen frequently. I’m sure that’s a case where it was the cheapest battery that they could buy, smaller or larger, where they could wrestle the terminals onto the posts.
Should be secured down. Especially FLA batteries. That acid will come out the vents and splash over everything, making a corrosive mess of things in the engine bay. May even eat some wiring. Who needs that aggravation.
My plow truck came with a ratchet strap holding the battery down. I upgraded to a group 65 and the strap remains. It does a remarkable job.
A bungee just changes the resonant frequency of the battery shaking its plates when the vehicle encounters bumps.
Just to confirm - I had not seen these until we bought our Toyota - a lot of cars use clamps on the bottom now. If you don't see anything on top take a look.
If the vehicles older (10-15 years)....About the same ratio as you. Less likely on newer stuff.
People that drive around with a bad battery needing to jump it off like it's a normal thing grinds my gears far more!!
