I'm in the middle of replacing my radiator & hoses, with some other incidental chores. Among other things, broke a small piece off one of the *plastic*(
)heater core inlet/outlet spouts
, & am praying the JB Weld repair will work.
The Neon's battery(Group 58) was installed in Jan '01 by the dealership, still works well, but while I'm doing all this it's the perfect time to replace it, since I had to remove it & the battery tray "system" for access to other stuff. Plus this battery has corroded battery bolts since new, gotta hunt up some new clamp bolts today while I'm at it.
I want easy access to replacement, at least from Austin TX to Little Rock AR. O'Reilly's SuperStart(6-yr, 2-yr free, $46) has side handles that may not fit my batt box. That pretty well narrows it down to the Auto Zone Duralast(7-yr, 2-yr, $56 in grp 58), or the middle-of-the-road model battery at Walmart(dunno, 2-yr, $? ~45-50). As far as I can tell Wal Mart doesn't carry the Group 58 size in the yellow EverStart model- none of the stores in my area have it.
Searching here at BITOG has put the AZ batt on my "short list", which as you can see is pretty doggone short. There are lots of O'Reilly's around now but those side-handles may be troublesome.
So waht do you think, the AZ or the WM battery?If the AZ is really a better battery then the $10 extra is money well spent. Or if you know of any other good contenders let me know. Thanks for any recommendations.
