I recently got a bunch of flow and filtration data for Baldwin filters. The data is related to the filters I use in my applications, but they are all pretty common filter sizes so I thought I would share the data on here for others.
The filters I inquired about are the B2/B2-HPG (FL1A), the B6/B6-HPG (PF-35), B1428 (PF1218), and the B9 (long PF-24). I use these filters on Ford, Chev, and Olds V8's, but they are used in many other applications as well.
The data is as follows:
B2 and B6 Filters
BX=2: 12 microns
BX=75: 30 microns
Established Micron Rating: 12
Average Efficiency: 85.2 %
Burst PSI: 200
Flow
3PSI: 1.5GPM
5PSI: 3GPM
10PSI: 5GPM
15PSI: 7.5GPM
20PSI: 9GPM
25PSI: 11GPM
B2-HPG and B6-HPG
BX=2: 6 microns
BX=75: 20 microns
Established Micron Rating: 6
Average Efficiency: 89.35 %
Burst PSI: 200
Flow
3PSI: 2GPM
5PSI: 3GPM
15PSI: 6GPM
25PSI: 9GPM
B1428
BX=2: 12 microns
BX=75: 25 microns
Average Efficiency: 89.44 %
Burst PSI: 300
Flow
3PSI: 2GPM
5PSI: 5GPM
10PSI: 9GPM
15PSI: 11.5GPM
B9
BX=2: 20 microns
BX=75: 40 microns
Established Micron Rating: 20
Average Efficiency: 73.05 %
Burst PSI: 200
Flow
My contact couldn't find any flow data for the B9, but he said that he estimated the flow based on the filtration area and the type of material to be:
10PSI: 7GPM (EST)
In any case, he seemed certain that the B9 would have a slightly better flow rate than the B2/B6.
All filters except the B6/B6-HPG use a ADBV made of nitrile rubber. All filters use a cellulose/polyester/glass blend for the media, except for the B9 which is all cellulose. The B2 and B6 share the same filter element. The B2-HPG and B6-HPG also share the same element.
After reading this data my biggest suprise was that the HPG filters were the worst flowing filters. I was also surprised to see that the B1428 has better filtering and flowing media than the B6/B2 filter. It seems to be a real bargin since I can get them for just under $6 CDN.
I am a little disappointed in the poor filtration of the B9 filter, but it does seem to have excellent flow. I guess since this filter is used on BOP V8's, some old AMC engines, some International gas engines and older industrial diesel engines, Baldwin decided the cellulose media is good enough.
Any comments?
B2 and B6 Filters
BX=2: 12 microns
BX=75: 30 microns
Burst PSI: 200
Flow
3PSI: 1.5GPM
5PSI: 3GPM
10PSI: 5GPM
15PSI: 7.5GPM
20PSI: 9GPM
25PSI: 11GPM
B2-HPG and B6-HPG
BX=2: 6 microns
BX=75: 20 microns
Burst PSI: 200
Flow
3PSI: 2GPM
5PSI: 3GPM
15PSI: 6GPM
25PSI: 9GPM
B1428
BX=2: 12 microns
BX=75: 25 microns
Burst PSI: 300
Flow
3PSI: 2GPM
5PSI: 5GPM
10PSI: 9GPM
15PSI: 11.5GPM
B9
BX=2: 20 microns
BX=75: 40 microns
Burst PSI: 200
Flow
10PSI: 7GPM (EST)
Any comments?
