Originally Posted By: gathermewool
Originally Posted By: heypete
A good way to avoid most malware is to use a browser other than Internet Explorer. IE has a long history of security problems, and is tightly integrated into Windows, so viruses often have free reign if they manage to find a security problem. A third-party browser like
Firefox,
Opera,
Google Chrome, or any of the other numerous third-party browsers will likely increase security. Firefox also has a bunch of
add-ons that can enhance things, such as ad-blockers and other features.
I've had the opposite experience using both Firefox and IE. I actually originally switched to Firefox after hearing so many bad things about IE. I hadn't had any problems in over a year - I too CTRL ALT DEL out of popups instead of clicking anything - with Firefox, but one day last month things started to slow down considerably, though Norton hadn't found anything. Since my subscription was up I decided to switch over to MS Security Essentials. The first run found two Trojans : /. I removed them, but a few days later Firefox was running slowly, and a new trojan was found after a scan with MSSE.
For the heck of it I loaded up IE after the trojan was removed to see if there was any difference. A couple of days later a warning popped up in IE saying that someone was trying to access my computer to UL another trojan. MSSE and IE blocked it, and I haven't had any problems since.
100% of the disinfections I have done on PC's are users of IE. You mentioned your Norton being expired, I would guess that was the culprit and not Firefox.
While I'm on the subject, I use AdBlock Plus and No Script with Firefox, it's amazing how many scripts that sites will try to run. I only allow the ones to run that enable site functionality. It's a bit tedious at first but after a while it learns where you normally go and the prompts are much less.
