Backup camera install problem
Suburban Washington DC
Posted about this on the, What are you working on, thread, and thought I was done, but noooo. Installed an aftermarket backup camera on the 15 Explorer Police car in the tailgate and connected it to the 4.2" screen connector as the instructions say. Connected the power wire to a keyed 12V source. Display worked and showed the correct image when I checked and tested during installation when I put it into reverse. Also worked fine after finishing the install. Then I go for a 20 minute drive and want to back into a parking space and the screen says something like, REVERSE CAMERA NOT AVAILABLE when I put it in reverse. So then I drive home, have some lunch, then check it again and now it's working again. Ideas what may cause this? Is it ok to have this powered constantly when driving instead of connecting it to the reverse lights? Could it just be overheating from that?
Res isn't too high. But I'd just connect it to the reverse lights so it's not powered all the time. I think that's how its typically done.
It really sounds like an intermittent connection issue. The display recolonizes that you put it in reverse but the camera is either not powering up or the signal wire is loosing connection. Does the display get its power from the camera or is it wired separately under the dash. Do you have a separate mini coax cable from the camera to the display, if so check the center conductor pins at all connections. Sometimes the center pin gets pushed back as you plug it in and just barely makes contact. A bit of vibration can cause it to loose connection or reconnect. If its loose in the connector you have to reach in and grab it with a pair of needle nose pliers and pull it gently until it locks into position.
With the reverse lights, I thought there would be an annoying delay for the camera to come on, but might try it.
Factory display.
OK so it could be a bad connection to the backup lights as well. Check to make sure you didnt get any insulation trapped in the wire crimp (if you crimped them} and that the ground connection is tight. It just acts like a weak connection someplace.
I am glad I found this post. I have the exact same problem. I bought an aftermarket pioneer stereo for my 2002 vette and installed a backup camera with it. It is a cheap Nitika camera I bought from Amazon (one of the highest rated and most popular backup cameras). I have the reverse trigger wire connected to the reverse light power, and the power and ground wired to the power and ground of the new head unit (same power and ground the old head unit was wired to). This way I can view the backup camera anytime by selecting it on the menu and still have it automatically come on when I switch to reverse.
It works great when I first turn on the car, but after driving the car for 30 minutes or so when I go into reverse the image flickers or goes completely black. If I only drive for 5 or 10 min it is fine. If I let the car cool down for 30 min or an hour after I lose the picture it works fine again.
Atikovi, did you find out why this is happening?? Is it the camera? I contacted Nitika and they replaced the camera free of charge but the same thing happens with the replacement camera. I ran new ground and power wires with thicker shielding from the camera to the head unit but still have the same problem. Hopefully you found a solution since I am at my wits end and will try replacing the camera with another brand next.
