Aftermarket backup camera fails when it's cold and wet out
PA
Problem description and troubleshooting steps to date below. Looking for any and all ideas for future troubleshooting. This is a fairly rare problem and my schedule almost never permits me to drop everything and troubleshoot right when it happens, so I'd welcome any ideas that might help me duplicate the problem and/or focus my efforts.
Voxx ACA800 license plate camera
Kenwood DMX908S touchscreen
Both professionally installed in our 2011 BMW 328i by a licensed dealer of both products, a little over a year ago.
The vast majority of the time, zero issues. Then, when the temp drops and it rains, 50/50 chance this happens:
The top ~25% of the screen is the actual camera image, albeit a bit washed out. The rest is garble.
When temps were stable – including this past winter, even in snowstorms – it was fine. Rain, snow, or cold individually don't seem to cause the problem. The problem seems to happen when the temp changes (downward) and/or the rain starts. Could be wrong on that but that seems to be the trend, from memory. It's certainly the trend in the past several weeks.
I've taken it back to the installer multiple times over the past year. They couldn't duplicate the issue even by spraying the camera with water. All connections appeared strong and free of corrosion. Wiggling the camera does nothing. No visible condensation behind the lens.
The camera seems to have two grounds: one to the car's body and one through the connector to the touchscreen. The installer moved the body ground to a different location on the trunklid and it seemed to help (prior to that, the whole screen was garble and the problem happened more frequently).
Then, after a few recurrences, the camera died completely. Black screen in all conditions. Installer replaced the camera under warranty, and the replacement was fine until a few days ago.
I was able to bring it back to the installer earlier this week. They again couldn't duplicate the issue. They moved the body ground again; this time, they fished it through a guide for the stock wiring harness into the trunk and fastened it to what looks like an unused factory grounding point on the trunk sheetmetal. Then, today, temps dipped slightly and it started raining, and the problem came back.
The touchscreen is working perfectly with zero other glitches AFAICT (knock on wood).
The installer is closing its car AV department this week, so I'm on my own with this now.
Anyone seen something like this? I'm doing my own digging but it's hard to sift through inapplicable search results (e.g. factory systems, cameras obscured by water but not malfunctioning due to it). What do y'all think?
It seems like you have a legitimate claim to ask the installer to replace both pieces or give a refund since they couldn't identify the problem. They refuse?
I suppose I could hound them further, but the odds of success don't feel high enough to be worth spending my time antagonizing people I otherwise really like. They've already put a lot of time into this for something that, at this point, looks like either something weird with this particular car or just a string of bad luck. Seems unlikely that the touchscreen is the issue because replacing the camera fixed the problem; if it's an issue with the install, I kind of don't want their installer to touch the car again; and trying to get them to hook me up some other way sounds like it'd invite weeks or months of further drama. We'll see...
Get what you're saying but it's a shame you didn't get what you paid for and they get off the hook.
Given the amount of time they've invested in trying to fix this, taking my word over and over again about problems they couldn't replicate, I think it's safe to say they've lost money on this install. At least I came away with a sweet touchscreen and a backup camera that works most of the time!
