A few weeks ago I performed the annual oil and filter change on our John Deere D140 lawn tractor. Everything went well and the lawn got cut the following week. After that cut I noticed a large puddle of clean oil on the shed floor. I checked the drain cap and oil filter and both were dry. Roll the clock forward another week... I cut the lawn and parked the tracctor in a different place in the shed. There was another large puddle of clean oil. Yes - I did top it up between runs.
Roll the clock forward another week. The lawn was cut and the tractor parked in another new location. Today I went out for another cut and noticed an oil spot the size of one or two drops. So how does a large oil leak fix itself? After cutting today I blew out the deck and under the hood with a leaf blower. Suddenly oil started spraying out as if it was under pressure and then settled into a fast leak. It turns out that the drain pipe from the block was really loose - 540 degrees of roatation to tighten it up. Blowing it off produced enough of a temperature differential between steel and aluminum parts to loosen things up and allow the oil to escape. Luckily this didn't happen while mowing at 85 degrees ot I would have lost an engine.
Have any of you experienced anything like this or did I just win the lottery?
