Autozone/STP Filter Changes
garageman402
$100 Site Donor 2026
Sometimes NorCal., Sometimes ATX, USA
STP now confirmed as Champion made
Very good sheet & Great work. 👏
I will say that STP goes through different companies for their rebranded filters but it appears the model numbers listed above are Champ labs.
Is this an actual valid change since the notice is dated 5/23/2024. Are these filter changes actually showing up on the shelves in AutoZones? That's the real confirmation on info over a year old.
Here's my post in the other thread about this:
The original item is a 5 page pdf, which I can't post, & when I converted to jpeg it only copied one page at a time, & they posted out of order. I left out the last page as it only had a few part numbers.
I just found this on AZ's site in the STP filter description page. At the bottom of the list, there is a link that brings up this info.
Locally the AZ STP XL and some basic blue STP have been have been Champ Labs made for a long time. Never seen, or for a long time, the PG made XL. It's always been AZ region specific which XL filter maker seen. It appears what this notice is showing is that 'where the STP XL and basic blue can' have been CL made the long time ecore auxiliary/outer base plate now removed by Champ. Same as AC Delco. That leaves only the protruding thread boss baseplate design as shown on right side. 'I' would not conclude that going forward this means 'all' STP XL and basic blue will be Champ Labs made.
The base plate cover was just an extension of the usual can crimp metal. I would guess they cut it back to save costs on metal. Most of this metal is probably imported, how else can they make oil filters so cheap. Made in USA from global materials is on so many things even food.
I bought a couple of the blue S12060 filters this weekend. They look different than the OP.
Are the "blue" filters acceptable to use for a 5K oci in a GM 1.5l turbo?
The blue (box and label) Carquest filters are the "Premium" model and rated for 10K miles. The red Carquest filters are the base filter.
At my local AZ, it varies by filter. The filter for my truck has the “leak tested” printing and is made in Vietnam. The STP filter for my wife’s car says made in China…and looks very different, finish wise.
