That's the modern equivalent to the Marlboro Man.
Only one thing missing; orange www.bullsballs.com on the trailer hitch.
Those things used to be known as Brodozers.
The cars are heavier now and have much larger brakes. You can fit 18" on the new Type R but the brakes are way larger than the ITR.
Wider tyres than necessary result in worse fuel economy and larger diameter rims than necessary result in a more uncomfortable ride plus increased susceptibility to wheel/suspension damage. When the above is being applied to ordinary everyday cars rather than sports cars then it has to 95% marketing.
You can say the same about suspension settings. I've been a passenger in a car with suspension so hard it defied belief. It was so bad the driver actually had to slow down which rather defeated the point of a car with a sporty image. Have buyers asked for cars this bad or is it the designers producing cars they think we should have ?
I don't get the modded cars with massive amounts of camber where they stick out of the wheel well.
Those days will never return due to the larger brakes. Stopping distances are much better now. Traction is better too.I pine for the days of 15" rims and bigger sidewalls.
True. On my truck the minimum rim size is 18" to fit over the rear brake disks. It came with 20s but I'm not sure a 10% diameter reduction would make much difference. It goes, steers, and stops just fine.Those days will never return due to the larger brakes. Stopping distances are much better now. Traction is better too.
Considering the fact that most everyone agrees on that wider tires will provide more grip, my statement is correct.I can say that larger rear tires DO NOT increase understeer...
My C5 has much wider tires on the rear...during AutoX, understeer is RARELY a problem.
Increasing tire circumference creates more contact with the road compared to widening. Benefits are a compliant ride and enhanced straight line traction. Cornering grip can be enhanced by stiffening the sidewalls, which low-profile tires offer. For passenger vehicles, taller tires with low profile sidewalls (requiring larger wheels) is the perfect balance.
Same here. I want a 17 inch rim, or under. Hate low profile tires.Maybe I’m boring but I’m the opposite LOL
Lol!My Geo Metro had 12" rims from the factory lol, I had to "upgrade" to the massive 13" wheels to find any tires 😂
