Autolite Double Platinum life?
Originally Posted By: DeafBrad
So my plan is to leave the Double Platinum plugs in for 100k miles and then replace them. For the most part I am following the manufacturer's maintenance schedule (100k mile plug changes) and wanted to confirm these plugs are able to do that.
Think "bathtub curve". Some will fail early. Some will fail extremely late. Most will fail somewhere around the middle.
The warranty isn't really an indicator of how long something will last, but a liability the warrantor is willing to take. There have been some horribly unreliable products with long warranties. The warrantor just accepts it as a cost of doing business, along with the understanding that many or most won't even bother to get a replacement. I mean, what sense is it to spend $5 to ship something costing $10, with the chance that the claim is denied? Some companies with legendary reliability have short warranties.
I remember when Mobil had they're craziness with motor oil warranties. They offered to repair engine damage if their oils were regularly used for at least the manufacturer's recommendation or up to 5000/7500/10,000 miles under any service conditions. That led to some awkwardness, since some assumed the protection ended after the mileage number, even though the fine print said that the carmaker recommendation was fine, like a Honda's 10,000 mile OCI under normal conditions.
Originally Posted By: NibbanaBanana
You leave them in there for a long time and then they don't want to come out. What's so great about not having to change spark plugs anyway? How difficult is it to change spark plugs? When you take them out they give you a good idea how your motor's doing. I use Autolite copper plugs for 30K miles. Never had a problem.
They can be tricky. I changed them out at around 80-90k on the Taurus I used to own, it was a waste fire system so they did have a little bit of wear on them and the gap did open up, gas mileage improved slightly after changing them. On the Mercedes M276 engine, you have to take the intake manifold off in order to change the spark plugs which is recommended at 60k because they use a multi spark ignition cycle which can fire up to 5 times in a single cycle. So now you go from a $100-$200 spark plug change to a $600-$800 job because of the intake manifold.
Ever try to do them on a transverse V6? You have to take apart half the engine to get to the back row of cylinders! While you're there, replace the valve cover gaskets and iridium spark plugs that last 100k so you don't have to do it again for a long time!
Luckily, the 4th gen Maxima has cutouts in the intake for easy access to the rear plugs/coils, so a spark plug job isn't that bad at all. But this is the exception, not the rule.
Since Denso and NGK use a special coating on their threads (which means you don't need to use anti-seize), they will come out easily after 100k
