Originally Posted By: AndyinAL
Advance Auto Parts. Johnson Control just like AutoZone, Walmart, Costco, Interstate...
Buy online, pick up in store. Use discount code TRT41 to save $40 off $100
Standard batteries are fine. Cramming more lead and plates into the same physical case is not better. Modern cars do not need 700CCA to turn over. Batteries were half that 50 years ago cranking 400+ cubic inch, high compression, carbed engines.
The best reason to try to get a few more CCA in your battery is a bigger margin for error-really cold temps, accidentally leave a light or lights on, or even some age can make a standard size battery fail when an oversized one will still get an engine started.
