I've a '94 Merc Sable 3.0L with the AXOD transmission. This transmission currently won't shift past 2nd gear.
Up until about 2 days ago this was working fine, shifting smooth with no problems. Now it shifts from 1st to 2nd with no problem, but it won't shift out od 2nd. It doesn't even try to shift out of 2nd.
This car has done this before, over the winter it did this for a few months, and then just went back to shifting normally.
About 2 days ago, immediately before this started, it was delaying the gear shifts, It was running to higher than normal shift points. Now it just doesn't shift. Also it's not throwing any codes.
I'm thinking that this is an electrical problem, a sensor maybe not telling the transmission to shift? I can't afford to take this to a garage right now. I can try to work on it myself.
What can I try to get this working?
