Auto-Rx ???? What do you think?
One thing to add......the product will only clean where the oil gets.....so don't expect it to clean any buildup that is outside of where the oil will be in regular contact.
If you have a powerful PCV system, that should not be an issue.
I also JUST orderd the stuff for the first time. What part of GA are you in? If your near by, i'd be interested in popping off our valve covers and see how our engines look afterwards.
Remember it is after the rinse phase you see the cleaning results. It is while your driving you feel the engine results of Auto-Rx and if your not driving way to fast the MPG gain.
ps. it sounds good to "pop off valve covers" remember you have to install new gaskets and if your not sure don't do it. Because oil leaks will be on you.
On The thread above ( i forget if it was a sticky) the guy popped off the cover on the nissan to snap before and after shots. The after shots looked real good. So good i want to witness it first hand and seing as my engine only has 90k and no sludge, i wanted to see how it would do on the OPs car, assuming it has high varnish and sludge.
