Does auto parking brake necessary if I only park on flat area? Whenever I park my lexus apply auto parking brake on, I feel it does more harm then good. I'm I wrong? Should I disable it ?
Actually, you should always apply your parking brake, even on level ground, to save stress on the parking pawl in the transmission, to build good habits, and to keep the mechanism working properly.Does auto parking brake necessary if I only park on flat area? Whenever I park my lexus apply auto parking brake on, I feel it does more harm then good. I'm I wrong? Should I disable it ?
Same in my F150.I apply the parking brake manually in the Tundra and Soul 100% of the time and the RX 350 has an automatic parking brake. I do it to take pressure off the parking brake mobobber in the transmission.
Unfortunately in the salty midwest, lack of use greatly exacerbates rusted/rotten cables.Here in the flat mid west, I never do on automatic cars
Do the cars with more rapid rear brake wear have traction control systems?I've grown to like mine. Perfection it's not: both my cars have eaten rear pads faster than normal, and I think it's related to that, the parking brake can exert enough force to drive a mostly stuck pad out, whereas under light braking not enough force would move said stuck pad. Result, rear pads wear faster than I'm used to, and I need to pay more attention to keeping them freed up. Not that hard to service during rotations.
On my cars they have been a pain to release. The service brake operation seems to only release, not unwind, regardless of what the internet says. 12V battery fixed the issue for me, easy to get them to crank all the way out.
Will say, at least they work. Unlike the drum brake parking brakes of my prior Camry and Tundra, those didn't work for beans IMO.
I know and seen what you mention.Unfortunately in the salty midwest, lack of use greatly exacerbates rusted/rotten cables.
Yes. However, they're FWD.Do the cars with more rapid rear brake wear have traction control systems?
Absolutly not. I live in pancake flat SE TX and have driven vehicles, both STD and Auto, and not once have I have applied the brake. Ever. After 40 years of driving, zero issues, zero problems, zero necessity.Does auto parking brake necessary if I only park on flat area?
