Comments appreciated.
No-mod car has been owned since new. Oil changed at 5066, 10386, 20316, 30273 and 41104, all with Audi 5w30. Often Run at 80-90 on weekends for 200 miles or so; short trips during the week; oil has never popped 250F. Half-way thorugh 3rd set of tires.
From Blackstone report:
The TBN for this oil was 1.0, so you've used up most of the active additive in the oil with the 10,867 mile oil use run. Universal averages show typical wear metals for an oil from this type of engine after about 6,735 miles run on the oil. Your oil use was longer, but we still found all wear from the engine at around average levels and in the correct balance to show normal mechanical parts inside. Air and oil filtration look okay. This was 5w30 engine oil with no gas, moisture or anti-freeze in it. If the low TBN doesn't bother you, try more miles use for the next sample.
Elements A6 UA
Aluminum 4 3
Chromium 1 1
Iron 17 15
Copper 9 7
Lead 1 1
Tin 0 0
Molybdenum 45 52
Nickel 1 0
Manganese 0 0
Silver 0 0
Titanium 0 0
Potassium 0 0
Boron 0 67
Silicon 7 10
Sodium 3 10
Calcium 1836 2307
Magnesium 0 330
Phosphorous 711 799
Zinc 834 960
Barium 0 0
Property Expected Were
cST @ 40°C
SUS @ 100°F
Visc. Idx
cST @ 100°C
SUS @ 210°F 54-61 55.9
Flashpt °F >365 370
Fuel% Anti-freeze% 0 0
Water% Insolubles% <0.6 0.5
Elements A6 UA
Aluminum 4 3
Chromium 1 1
Iron 17 15
Copper 9 7
Lead 1 1
Tin 0 0
Molybdenum 45 52
Nickel 1 0
Manganese 0 0
Silver 0 0
Titanium 0 0
Potassium 0 0
Boron 0 67
Silicon 7 10
Sodium 3 10
Calcium 1836 2307
Magnesium 0 330
Phosphorous 711 799
Zinc 834 960
Barium 0 0
cST @ 40°C
SUS @ 100°F
Visc. Idx
cST @ 100°C
Flashpt °F >365 370
